Samsung PS51D6900DSxxc- Stays in standby
  • curro
    • Dec 2012
    • 15
    • España
    Re: Samsung PS51D6900DSxxc- Stays in standby
    Bad news, as usual, without voltage goes.
    Bridges have done horizontally.
    I do not understand, I made a few days ago and had the bridge voltage PSON goes.
      So, you do not get voltages when triggering PSON?
      Have you tried VSON, if it is separate?
      • curro
        • Dec 2012
        • 15
        • España
        Exactly, continued without voltages, with PSON activated
        Sorry I do not understand that separate .. I have not touched anything VSON
        I'll post a picture
          Sometimes these PSU boards have a separate VS-ON for turning on the plasma panel voltages.
          How are you providing signal to PS-ON?
          • curro
            • Dec 2012
            • 15
            • España
            PSON connect to GND.
            It should also be connected to GND Vs_on?
              Yes, try that too.
              • tw2005
                • Oct 2011
                • 6458
                Tom I believe there is a panel on command and I'd consider trying disconnecting the buffers or go deeper on the ymain or disconnecting the ribbon to the logic main
                have any checks on fuses/shorts etc been done yet?
                i have had on of my PS50Q91 models stuck in standby because of shorted buffer and ymain.
                I just can't remember how I fluked the set to turn now but I mucked around with the Ymain area and maybe the logic card.
                Sorry I can't be more helpful.
                The only other problem I see is on this the y is feeding the x, on mine they fed inderpendantly VS from the PSU.
                • curro
                  • Dec 2012
                  • 15
                  • España
                  #28
                  Well still trapped in stby.
                  Tomorrow if I have some time, desmontare the psu and will review again.
                  Thanks to all for the help, Tom66 thanks for the effort and patience.
                    09-07-2024, 05:50 AM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
                  • Kaar3l
                    Samsung QLED QE65Q7FNAT only standby light
                    by Kaar3l
                    TV: Samsung QLED QE65Q7FNAT
                    PSU: BN4400940A
                    MB: BN94-12832K
                    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                    09-24-2024, 01:35 PM
                    09-06-2024, 11:40 PM
