Dish Network DTVPal DVR Problem
  • preacherman
    • Nov 2012
    I have a DTVPal DVR that was made by Dish Network. They stopped producing and servicing this unit.
    The problem I have is that the picture will intermittently distort like it's receiving a weak signal. After so many of these the unit will lockup, and need to be reset. The signal strength is good, and I don't see anything obvious on the mainboard or power supply board.
    I tried heating the boards to see if the problem would get worse, but it didn't. I tried disconnecting the antenna to see if it would do it when just watching a recorded movie, it still does it.
    I've not checked to voltages yet.
    Anyone know what the problem might be?
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
  • BOSCHNJAK
    by BOSCHNJAK
    ABOUT ME INTRODUCTION FILE
    2
    024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
    2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
    2022 BEV, PROJECT ?
    2021 BEV, PROJECT ?
    2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
    2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
    12-28-2023, 02:09 PM
  • davg
    Home network connection problem
    by davg
    I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
    03-06-2021, 07:13 AM
  • jaaa1976
    HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
    by jaaa1976
    Hi everybody !
    I bought this pc from ebay with error - There is a problem with the security device on the unit
    please fix my bios.
    Model: HP Elitedesk 800 G4 mini PC (65w)
    serial no. 8CC93326J4
    PRODUCT NO. 4KW04ET#ABU
    32- 16mb bios attached
    Thank you so much...
    12-19-2024, 06:48 PM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
