LCD19DVDID-107-Channel stuck when left
  • blackillusion
    • Nov 2010
    • 16
    Hey guys I have this
    Technika LCD19DVDID-107
    When you start it up you can channel hop, but it does start to get sluggish.
    If you leave it on a channel and come back 5 minutes later its locked on that channel and you cannot change with either the remote or panel buttons.
    I opened it up, power supply seems ok although it had a bulging cap on the secondary side. I replaced that, and esr checked the cap it was faulty.
    Now this problem goes away if you turn off then back on. You can turn to standby from remote or panel.
    Re: LCD19DVDID-107-Channel stuck when left
    Unplug the button board and see if it then works well with remote.
    • blackillusion
      • Nov 2010
      • 16
      Hi tom66 thanks for your response. I have just tested this to no change.
      Whats strange is that the - stby, vol+, vol- and menu buttons all work when the ch+/ch- stops. On both the remote and the panel board.
      Look like its going to be a long one. I'm guessing that a capacitor on the line for ch+/- is going down once its filled? sound likely?
      Shame I have no schematic things are much easier then.
        No, I would doubt it's a capacitor. It's probably got some corruption in the channel table that it doesn't like. Do you know who makes this set, any part number on the main boards? I can look up how to reset it to factory settings.
        • blackillusion
          • Nov 2010
          • 16
          Okay tom66
          Power supply has:
          ACP007-G
          Mainboard has:
          plv3619d-01-03
          No obvious manufacturer marks
            Can you post a picture. PLV might be Proview...
            • blackillusion
              • Nov 2010
              • 16
              Hi tom66 I'm at work at the moment but if this helps it is the same one here:
              http://item.mobileweb.ebay.co.uk/vie...d=130658401833
              If that's any use. If not let me know and I will try to get a photo asap
                Hmm, nothing stands out to me as to who the OEM is. Technika (Tesco) just buy in stuff from China with their name printed on it, so it could be anybody...
                • blackillusion
                  • Nov 2010
                  • 16
                  Hi tom66, yeah ok no worries. I will have a good look over the board to see if there are any other markings. Thanks for your efforts
                  • blackillusion
                    • Nov 2010
                    • 16
                    Im looking to have another look at this soon. but if anyone had any ideas I can check. Unfortunately no schematic so its a bit blind
                    • CoinCoin88
                      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                      by CoinCoin88
                      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                      09-15-2025, 03:36 AM
                    • Sik_6ty_Sixx
                      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                      by Sik_6ty_Sixx
                      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                      02-18-2025, 05:06 AM
                    • karatzdi
                      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                      by karatzdi
                      I know some might say... just buy another one. Sell it as parts..!
                      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                      Spent some time downloading the Service...
                      06-11-2024, 08:38 AM
                    • HelpMeRepair
                      Yamaha RX-A3010 left channel no signal
                      by HelpMeRepair
                      Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
                      what I did so far ,
                      factory reset
                      test all other channel
                      tone test
                      dissasemble and look , visual inspection witout full dissasembly
                      looked at all the mosfet for temperature to see if they eas operating
                      scratch my head couple of time
                      thanks in advance all help is appreciated , service manual are welcome too ! =)...
                      11-14-2024, 02:48 PM
                    • CDNBrewer
                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                      by CDNBrewer
                      Hello Everyone,
                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                      Symptoms:
                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                      • I swapped the Left and Right surround
                      08-05-2025, 09:29 PM
