LG TV Capacitors
  • Phreak
    • Oct 2012
    • 6
    LG TV Capacitors
    Hey guys
    Just trying to fix my lcd tv and I think I have found the bad capacitors . The question is what capacitors do I need to replace them? I understand the voltage should be as high as I can get but the uf needs to remain the same. Can anyone shed some light about what type of capacitors I need for the capacitors in the attached pics. I am unsure what the numbers mean but I am guessing the middle number is the uf and the end number is the volts. Am I correct?
    Cheers
    Tristan
  • OniJon
    Computer Expert
    • 82
    • Finland
    Re: LG TV Capacitors
    Yes, you need to replace them with same kind SMD capacitors. And the markings are like you said, middle like 220 or 330 is uF marking. Last line 25 or 35 something is volts.
    • dragon3x
      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
      by dragon3x
      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
      power on.
      Here are some examples :
      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
      switching supply area).
      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
      than 6.3 V.)
      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
      I replaced capacitors with aluminum-polymer.
      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
      03-21-2025, 02:46 PM
    • Loretto
      Samsung SMPS BN44-00339A
      by Loretto
      this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
      I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
      I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
      I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
      03-29-2025, 08:30 AM
    • Loretto
      by Loretto
      03-28-2025, 10:28 AM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
    • supermattch
      HP 15dy-2021nr wont power on mystery volts
      by supermattch
      Hi everyone.
      I am diagnosing my personal laptop, because it wont power on and no leds light up.
      At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
      Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
      09-23-2025, 12:13 PM
