LG 50PQ10R Ysus board Problem and replacement parts help!
  • XaroRSA
    • Oct 2012
    • south africa
    Greeting Forum!
    I am currently trying to fix a Plasma TV(50PQ10R-AFB).
    When starting up the TV, I can measure the main power supply going on, then disabling via the nice relay "click".
    When disconnecting the YSUS board, the main power supply does not click off.
    Upon inspection of the Ysus board, the input 4A fuse was blown, and the 30J124 IGBT's were shorted.
    All capacitors have been replaced.
    Can the forum please advise me on a equivalent IGBT that will work with this TV?
    And if I replace the IGBT's, do I need to adjust and resistors or pots?
    I also notice 2 wires that connect to the lcd driver boards, seems like a factory edit, just wanted to hear if anyone else has this? They are on the P207 connector on the YSUS board.
    The 30J124 IGBT seems to be like a dinosaur, and this is the info i could find on it.
    Breakdown Voltage VCES (V) @Ta = 25˚C ===600V
    IGBT Current Rating IC (A) @Ta = 25˚C (PULSED) ==200A
    Collector current rating (DC) == 30A
    N-channel device.
    Can anyone please advise on a replacement part? Do I need to be very concerned about the pulsed current being 200A?
    Regards and Thank you!
  • Alekov_31
    IGBT replacement
    by Alekov_31
    Hi guys, I'm repairing a welding machine which has 12 blown IGBTs in the power supply. The blown IGBTs are no longer available and has a replacement part that has lower power dissipation. The original IGBT is SGP30N60HS (250w) and the replacement is IGP30N60H3 (187w). Is there a problem to change with the replacement part or I have to search with higher power dissapation
    11-23-2023, 02:36 AM
  • boosti45
    Macbook pro logic board replacement parts quesion
    by boosti45
    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
    08-21-2024, 05:23 AM
  • samoelec
    Trying to understand how to find best replacement cap for old parts.
    by samoelec
    Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
    Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
    The power supply board is exactly the same from this post so I'll just steal it for now.
    I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
    04-01-2024, 03:39 AM
  • PlasMatt
    LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
    by PlasMatt
    I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
    09-20-2025, 06:50 PM
  • tranthengoc92
    Looking for MSI replacement parts GF76-11UEK
    by tranthengoc92
    Hi everyone. I caused a short by removing the eDP cable without unplugging the battery. A component near the connector smoked. Does anyone know the value/part number of this burnt component? Looks like it's part L9 in the schematic...
    11-21-2025, 08:28 PM
