the lcd is turned on and suddenly it gets on a dark blue screen. i try change the input source but i just have audio, i need to turn it off and wait some minutes and try several times turning it on and off to get back the image on the screen
Jvc Lt-47p789 Just Have Audio, No Image On It. The Complete Screen In Dark Blue
Re: Jvc Lt-47p789 Just Have Audio, No Image On It. The Complete Screen In Dark Blue
Is this a plasma or LCD display? I suspect the main board. Someone else here had a similar problem.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
see attached information I think this might be your problem hope this helpsAttached Filesif you find these attachements useful please consider making a small donation to the site
Ron Driver,BSEE,CET,ISCET,NESDAComment
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by speedtime07hi everyone ,
There is an image on the external computer screen ,
flexi cable test ok - screen test ok -
What alternative should I look for?
thank you for your support​ -
by som_b1Hello. I encountered such a problem - the MacBook screen lights up but does not display an image. Almost like a flexjgate in reverse). Maybe someone has encountered such a breakdown. The problem is in the cables or maybe in the t-con?11-05-2025, 12:20 PM
- Loading...
