Bad T-Con replacement board?
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Re: Bad T-Con replacement board?
    Hi stretch.0790
    i am afraid you have to use only one thread for your problem instead of posting in multiple threads. this will make our work easier.
    • mikew67
      • Aug 2012
      • 20
      Please see the followup to this thread in my new thread at:
      https://www.badcaps.net/forum/showthread.php?t=22606
      (Might as well consider this one closed.)
      Mike
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
      • howardc64
        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
        by howardc64
        • Prior owner tried a replacement main board. No difference.
        • Samsung 2x red blinking standby LED = panel fault
        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
        07-19-2025, 10:54 PM
