LG 50PC55-ZB stays in stand-by
    Re: LG 50PC55-ZB stays in stand-by
    Do they show as shorted? Wow. Those IGBTs should be <£5 each... if you can source them!!
    • laszlo31
      • Aug 2012
      • 25
      • Hungary
      Yes, 3 out of 4 show shorted Collector-Emitter, only 1 is properly insulated and can be opened or closed with applied Gate voltage.
      Would you recommend me checking the remaining 2 IGBTs under the other heatsink?
        If you can. Though usually only the FETs in one group will go at once.
        • laszlo31
          • Aug 2012
          • 25
          • Hungary
          I got lucky as a guy is selling RJH3047 IGBTs at 1€/piece in my city so I can pick them up tomorrow. I hope the TV will get out of protection mode and the replacement transistors will not go blown right away. Keep your fingers crossed.
          If fuses are OK on the boards, would you say that the IGBTs just got too old or would you recommend some extra precaution before I solder the new components and switch the set on?
            One probably failed and took out the other three. These TVs run hot, accelerating failures.
            • laszlo31
              • Aug 2012
              • 25
              • Hungary
              #26
              I got the replacement IGBTs, replaced them but unfortunately the TV still clicks back to stand-by as the Z0_SUS_UP pin doesn't go up to 5V as (I guess) it should.
              The chirping sound became louder from around the upper heatsink. Being afraid of shorting another set of transistors I tried only few times powering up but I got no luck. Desoldered the components again and checked. At least the transistors and the rectifiers are still OK.
              I try to upload a short videoclip so somebody might recognize what would give such a distinctive chirping metallic noise.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #27
                could it be ic701 as in this kit
                http://www.ohmsupplies.co.uk/Repair-...55-EAY32957901
                • laszlo31
                  • Aug 2012
                  • 25
                  • Hungary
                  #28
                  I will check IC701, thanks for the tip.
                  Here's a link to a short clip that has the mentioned sound. Please listen to it and let me know if this sounds familiar or typical.
                  http://videa.hu/videok/tudomany-tech...Qv1L9apH4OXLFX
                  • laszlo31
                    • Aug 2012
                    • 25
                    • Hungary
                    #29
                    Unfortunately Youtube uploading is unbearably slow so I had to upload the short video to the Hungarian version video sharing site.
                    Please listen to the sound and try to guess what makes it...Thank you.
                    • laszlo31
                      • Aug 2012
                      • 25
                      • Hungary
                      #30
                      I still haven't found the culprit.
                      What are the chances that if all PSU voltages are OK with connectors removed, under load these voltages are off specs? Should I build some test device with light-bulbs?
                        Bad capacitors could cause the issue. However, you should be able to test the voltages with the boards connected and see if any drop out.
                        • laszlo31
                          • Aug 2012
                          • 25
                          • Hungary
                          #32
                          Due to the nature of the problem (TV doesn't power up but goes back to stand-by) I have difficulties measuring voltages under load. My window of opportunity is few second every time that should be enough but I am afraid of ruining components as a quite harsh sound is coming from the upper part of the Z-SUS. Few posts earlier I posted a link to a short video, I would appreciate if you could listen to it and at least share your opinion if this sound is a sure sign of dying components or not...
                          • laszlo31
                            • Aug 2012
                            • 25
                            • Hungary
                            #33
                            Checking all components on the Z-SUS I came across a shorted diode next to the IGBTs that were previously replaced due to short. Desoldering the diode, it tested OK but both empty pads were measured shorted to the GND of the Z-SUS. See attached picture. Following the printed wires it turned out that 3 pins of a IRS21064S driver IC cause the short. See attached data sheet. Having limited experience in IC testing could you please advise whether this IC seems faulty.
                              The IC shouldn't be able to short from Vs to Ground but I suppose it's plausible. In theory, the high voltage and low voltage sides are separate. The shorted IGBT could zap the driver, potentially.
                              • laszlo31
                                • Aug 2012
                                • 25
                                • Hungary
                                #35
                                Hi All,
                                After several evenings on component level troubleshooting and isolating the issue at a faulty 14 pin IRS21064S driver IC I decided to order a new Z-SUS that arrived today. After replacing the board TV works as a charm. Family happy. I learned a lot about plasmas. Thanks for the support and advice.
                                László from Hungary
                                  I'm glad you fixed it, sorry that I couldn't offer much help. Enjoy the TV.
                                  • laszlo31
                                    • Aug 2012
                                    • 25
                                    • Hungary
                                    #37
                                    Sometimes giving hope is just as important as giving a solution...Personally I even consider more important if someone wants to learn. And I do. Thanks.
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • fharris1977
                                      Vizio D50u-D1 Dead Set No Standby
                                      by fharris1977
                                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                      12-28-2023, 10:25 AM
                                    • Crystaleyes
                                      Samsung BN44-00259A standby question
                                      by Crystaleyes
                                      Hi all.
                                      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                      08-11-2023, 05:15 AM
                                    • reessi
                                      JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                      by reessi
                                      I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                      You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                      Years ago it had some bulging caps...
                                      04-26-2021, 11:42 AM
                                    • psssst
                                      Yamaha TSX 120 Standby Problem
                                      by psssst
                                      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                      03-01-2024, 07:25 AM
