TOSHIBA 42HP95 no start
  • tvduude
    • Jul 2012
    • 67
    i got some crazy hair up my bonnet and wanted distressed plasma to try
    an fix.
    so got this TOSHIBA 42HP95 attracted to the price tag..
    December 2005, i think i should have when for something newer.
    was wondering if you guys want to help me fix it. i dont have a clue.
    just alot of blinking from a red LED at the power button.
    checked the main fuse..its good.
    i pulled the big cooling fans for cleaning...theres alot of caked dirt built up in there.
  • tvduude
    • Jul 2012
    • 67
    Re: TOSHIBA 42HP95 no start
    already found this thread:
    https://www.badcaps.net/forum/showthread.php?t=13431
    currently looking for this seine board and the PJ63 mentioned to identify the said
    common issue and bypass tuner etc.
    • tvduude
      • Jul 2012
      • 67
      ok yes now we're talking.
      the PJ63 removed gets my tv started up however my pic looks blurry on bottom half and
      the guide or source menu comes up but the tv wont stay on for more than 10 seconds or so.
      must hit power button to get it back on after these 10 second shutdowns.
      edit:
      apologies.. premature..
      i reconnected the big cooling fans and the system appears to aware i did.. on for a few minuts now..looking at the internal "TVGuide" screen.
      yes defineately a blurry area left lower quadrant is blurry.
        Take a picture of the fault...
        • tvduude
          • Jul 2012
          • 67
          photos:
          http://photobucket.com/blurs
          the bottom tvguide ad is almost entirely within the blur area. its not my cam...thats what i see here.
          • tvduude
            • Jul 2012
            • 67
            um.. after 30 minutes or so of snowy screen the tv shut itself down.
              It's hard to see the fault, but to me it looks like a lower Y buffer failure.
              • tvduude
                • Jul 2012
                • 67
                sorry ..should have mentioned that i'm not a qualified tech but more of a committed enthusiast / mechanic.
                  If the TV shuts off in 30 minutes with no signal that may be normal.
                  You should change the Y buffer soon as it could fail damaging the Y sustain. The Y buffer connects through to the plasma panel - it's the one with lots of little black squares on it.
                  • tvduude
                    • Jul 2012
                    • 67
                    I take it then that this y buffer is either a board or a component module?
                    looks like?
                    also:
                    the blur areas seem to be the bottom corners but not the bottom central as much and the left is worse than bottom right.
                    also 2:
                    yes the central bottom one-third does not suffer, is limited to left and right or
                    express this way 1/3 and 3/3 but not 2/3.
                    lets try a 3x3 grid thats nine blocks. its blocks 7 and 9 that are blurry..
                      The Y buffer is a replaceable board. It looks like this.
                      http://i.ebayimg.com/t/Toshiba-42HP95-Y-Upper-Buffer-SU-Board-TNPA3189AB-/03/!BqVpfR!!Wk~$(KGrHqQH-E!EuYz1,UnDBLvTmqC23w~~_3.JPG
                      Looks like your TV uses a Panasonic plasma panel. Very nice! Panasonic produce some of the best.
                      • tvduude
                        • Jul 2012
                        • 67
                        ok yeah i see .
                        EZ5902T
                        suitable replacement numbers? i see ebayer listing a EZ5604T.
                        • tvduude
                          • Jul 2012
                          • 67
                          so you think my crisp will come back?
                          also,
                          its ok to run in this tunerless mode forever..?
                          a nice monitor is ok for me.
                          • tvduude
                            • Jul 2012
                            • 67
                            ten four ,
                            Panasonic ..aahh yes. (head bow)
                            • tvduude
                              • Jul 2012
                              • 67
                              TNPA3556-something.
                                http://www.ebay.com/itm/Panasonic-TN...item3a77b5ab55
                                Not a bad price for a replacement, they are rare failures.
                                • tvduude
                                  • Jul 2012
                                  • 67
                                  so all these used boards are from tvs that would have still worked more than
                                  decent as monitors via this PJ63 pull?
                                    I expect they are pulls from TVs with cracked screens.
                                    Just checking, is this the board on the left hand side of your TV (looking from the rear?) It should be on the vertical edge of the screen, and there should be another board above it (the Y upper buffer.)
                                    • tvduude
                                      • Jul 2012
                                      • 67
                                      i obtained the 3556 number form a board horizontal along bottom behind the
                                      input panel.
                                      have i gone in the wrong direction?
                                      ... yes i did.
                                      TNPA3190 is the far left lower board.
                                        Yeah you want the boards going along the vertical of the panel.
                                        Take a picture if you're not certain.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
