50" Samsung Plasma (model number PS50Q91HD) - possible purchase
  • psmedley
    • Apr 2012
    • 144
    Re: 50" Samsung Plasma (model number PS50Q91HD) - possible purchase
    Well my 1SS184 diodes arrived today - got them installed, but can't test it out yet as I had removed to 20 ohm and 10k ohm smd resistors for testing, and in the process or replacing them I busted one 20 ohm resistor and lost another one. Fortunately, I had already ordered replacements which should be here any day now!
      Before you blow some more FETs test it with a 100W light bulb in series...
      • randtek
        • Oct 2011
        • 280
        • US
        #63
        FYI, When you first replaced the Mosfets, probably the reason they failed while you were away from the set is that Samsungs remember the current power on setting. If unit was on when it failed, as soon as standby power comes up, unit will attempt to turn itself on. It probably turned on while you were away from the set and blew the mosfets.
        • retiredcaps
          • Apr 2010
          • 9271
          #64
          From the USA or Thailand?
          --- begin sig file ---
          --- end sig file ---
          • psmedley
            • Apr 2012
            • 144
            Can you explain more on where exactly the wire in the bulb?
            • psmedley
              • Apr 2012
              • 144
              USA - mailed on 29th June, arrived 9th July - 10 days - not bad for the USPS
              • psmedley
                • Apr 2012
                • 144
                blew as they weren't secured to the heatsink, so overheated?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #68
                  https://www.badcaps.net/forum/showpo...07&postcount=7
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #69
                    That is really good considering that includes the July 4th holiday. One of my ebay orders from the USA has been stuck in the sorting facility for 5 days now due to the July 4th holiday. :-(
                    • psmedley
                      • Apr 2012
                      • 144
                      OK - I also read http://smpstroubleshooting.com/power...oting-secrets/
                      This power supply has two fuses though, F801 immediately adjacent to the AC input, and F803 which is near the mosfets that I found blown.
                      I also read about failed startup caps causing high voltages and blown parts, so I'm thinking that as I have replacements, I'll replace all the caps I can on the hot side of the power supply.
                        In series with Live/Active. The bulb will light if a short persists.
                        • scokljat
                          • May 2012
                          • 275
                          • Croatia
                          #72
                          I found this thread (and some other) so exciting and tense like a good book ;-) What will happen next? Who is the bad guy, victim or the killer?! We have some usual suspects here, lot of victims, actually it's double murder for now. Clues are scattered all over 50 inch crime scene!! Maybe it's time to call fancy CSI chicks to take a look ;-)
                          Well, I hope it will be a happy ending. I'm also waiting for IPM delivery for my 42" repair from other thread. It usually takes 15-30 days for stuff to come to Croatia... It will be a long wait. Till then, I wish you luck!
                          Cheers!
                          Suad
                          • psmedley
                            • Apr 2012
                            • 144
                            Hmm 100w incandescent light bulbs are like hens teeth here - would a 72W halogen 240v globe suffice?
                            • psmedley
                              • Apr 2012
                              • 144
                              Oh, and once I find a 100W globe, when I power it up, should I have all the sub-boards connects to the power supply?
                                Everything should be connected and try to turn the TV on though I'd expect the TV to not power on properly with the bulb in series, but it will prevent a short from causing more issues.
                                • psmedley
                                  • Apr 2012
                                  • 144
                                  Thanks Tom - I'll assume that if I can't find a 100W globe, that two globes in series adding up to 100W would suffice?
                                    That should be fine, just make sure not to use anything with an electronic or magnetic ballast, you -must- use an incandescent or halogen bulb.
                                      Thinking about it, it might be better to use two 50W in parallel, or equivalent. You can use less, but you can't be sure the PSU will even start up into standby.
                                      • psmedley
                                        • Apr 2012
                                        • 144
                                        OK it's all back together... just gotta try find a suitable globe on the way home from work tomorrow before I fire it up
                                        Took the opportunity to replace a bunch of shitty samyoung caps with rubycons too
                                        • psmedley
                                          • Apr 2012
                                          • 144
                                          Found a 100W spotlight Unfortunately, when I turn the TV on I get relay clicking and the light flashes on/off inline with the relay.
                                          The fuse for the mosfets is still good.
                                          Ideas?
                                          • porfyriadhs
                                            Samsung Plasma PS51D6900DS Bootloop
                                            by porfyriadhs
                                            Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                            Thanks a lot !!
                                            10-19-2023, 11:31 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • CDNBrewer
                                            Samsung Plasma PN43D450A2D No Power
                                            by CDNBrewer
                                            Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
                                            This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
                                            I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
                                            When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
                                            03-02-2025, 04:59 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
                                            09-07-2024, 05:50 AM
