Magnavox 42MF521D/37B
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Magnavox 42MF521D/37B
    Find the datasheet for 7061 (likey your SMPS IC). Find which pin is VCC. See if the VCC has continuity to the positive leg of the capacitor. If yes, that is the startup cap.
    OR measure the the DC voltage of SMPS IC VCC with respect to SMPC IC GND. Then measure the DC voltage across the cap that you think is the startup. Both DC voltages should be identical.
    --- begin sig file ---
    --- end sig file ---
    • junktv
      • Nov 2010
      • 3065
      Looks like pin 1 is VCC for a TEA1507P. So it's the 100uf 25v cap.
      Haven't said it yet but thanks to you guys taking time out of your day to help others.
      • retiredcaps
        • Apr 2010
        • 9271
        1) 11V DC is the required for the SMPS to start.
        2) What is the DC voltage across the 100uF 25V cap?
        3) What is the DC voltage of pin 1 (VCC) using pin 2 (GND) for ground?
        4) Are any of the voltages fluctuating?
        • junktv
          • Nov 2010
          • 3065
          Both bounce from 1.4-11.
          • retiredcaps
            • Apr 2010
            • 9271
            Replace the cap first as it is the easiest and retest/remeasure. Use something like Panasonic FC.
            http://www.digikey.com/product-detai...0269-ND/266278
            • junktv
              • Nov 2010
              • 3065
              Since I have to order them I figure I might aswell replace the rest while i'm at it.
              3 P10269-ND 100UF 25V FC
              1 P11232-ND 47UF 35V FC
              There isn't an FC in 6.8uf 50v but there is a KG P936-ND and GA P14509-ND. I guess KG seems like it would be best since the GA has 5ma less ripple than the original capxon KM.
              The 2.2 NP is a bi-polar with 25 ripple. It looks like digikey only has a nichicon VP UVP1H2R2MDD-ND instock with that spec or a panasonic SU P1197-ND with only a 18ma rating.
              See anything wrong with using the P936-ND and UVP1H2R2MDD-ND?
              Any other parts i should grab just in case while i'm at it?
              • TechShui
                • Jun 2011
                • 148
                Have you checked the scaler board yet?
                I've worked on Magnavox LCD TVs where BOTH the power and scaler boards were bad.
                Specifically, the caps on the power board are a very common problem, and the IC that generates 12V on the scaler will sometimes blow, leaving a pinhead-sized hole on it.
                • junktv
                  • Nov 2010
                  • 3065
                  I replaced the cap and i'm getting the same readings.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    That leaves 2 likely possibilites.
                    1) The SMPS itself is bad. What is the resistance between pin 1 and 2 on the SMPS?
                    2) There is something shorted on the power board causing the SMPS to fluctuate. Likely candidates for shorts might be diodes 6056, 6055, 6054, the diode above 3081, 6066, and others in that general area.
                    Use the diode check function to measure each. You should have two readings per diode. One should be between 0.3 and 0.8V and the other should show "out of range".
                    • junktv
                      • Nov 2010
                      • 3065
                      Pins 1-2 does a short count up to about 20 @20k then shows open.
                      6062 near 3081 is reading 001 both ways in circuit and 520/0 out
                      6054 599/0
                      6055 606/0
                      6056 492/0
                      6066 516/0
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #31
                        6054 599/0
                        6055 606/0
                        6056 492/0
                        6066 516/0
                        The above all look okay.
                        1) Also test 6059, 6075.
                        2) See if 6076 and the other 3 pin IC on the same heatsink are shorted. Test pins 1-2, 1-3, and 2-3.
                        3) See if two ICs mounted on the heatsink above 3081 are shorted.
                        PS. If the photos are more clear and sharp, I could give the actual numbers.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Test IC above 5062 for shorts.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Another test to try is to disconnect all your boards and see if the startup cap voltage still fluctuates or not.
                            • junktv
                              • Nov 2010
                              • 3065
                              6059 is all over the place and climbing but was fine when i pulled it.
                              6075 755/0
                              Not sure if i should be using diode check so they will be the second set.
                              6076
                              1-2 climbs & climbs to inf
                              1-3 0 & 000
                              2-3 climbs & 203
                              6071 same sink
                              1-3 0 & 000
                              2-3 climbs & 276
                              above 3081
                              7057
                              1-2 open & inf
                              1-3 open & 775
                              2-3 open & 482
                              7062 same sink
                              1-2 open & inf
                              1-3 open & 659
                              2-3 open & 470
                              I guess you mean the 2 pin deal on a heat sink labeled 6062 next to the large cap. It reads open and 443/0 with diode check.
                              I was testing the board on my kitchen counter not hooked to anything else when reading voltages. Btw i didn't replace the other small caps yet just the start cap/
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                6076
                                1-3 0 & 000
                                2-3 climbs & 203
                                6071 same sink
                                1-3 0 & 000
                                2-3 climbs & 276
                                1) Well nothing seems obviously shorted. I believe 6076 and 6071 pins 1-3 are supposed to be 0 and 000 if they are dual diodes.
                                2) If they are dual diodes, then test it like pins 1-2 like a regular diode and pins 2-3 like a regular diode. You should have 4 readings.
                                I could tell if they were diodes are not if they used pcb designations like D601 and D602 rather than meaningless 4 digit numbers.
                                3) If you have tested all the diodes and there are no shorts, then you could try replacing the other caps or try replacing the SMPS IC.
                                4) findchips.com shows no stock for the SMPS IC so you will have to purchase from ebay.
                                5) If you buy the SMPS IC from overseas, it is $4.40 total. If you buy from the USA, the cheapest one is $11.60.
                                6) There could be something else shorted on the board causing the fluctuation, but the most likely candidates are the diodes.
                                • junktv
                                  • Nov 2010
                                  • 3065
                                  The first numbers where 20k ohm and second in diode mode.
                                  To fill in the info on the chips they are.
                                  6052 is a STTH8LD6FP voltage rectifier.
                                  6076 is a STPS40H100CW schottky rectifier.
                                  6071 is a MBRF10H100CT schottky rectifier.
                                  7057 is a W26NM60 zener protected mosfet.
                                  7062 is a W18NK80Z zener protected mosfet.
                                  Forgot to label 6051 GBU8J bridge rectifier.
                                    "3 P10269-ND 100UF 25V FC
                                    1 P11232-ND 47UF 35V FC" May be I am wrong, but I see 4 bad caps (3 are grouped together, and one at the bottom right of the picture).
                                    Since this board has PFC, what dc voltage do you get at the main DC filter cap when the TV is off and when TV is on?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      Originally posted by budm
                                      "May be I am wrong, but I see 4 bad caps (3 are grouped together, and one at the bottom right of the picture).
                                      He replaced them in post #8 with an updated picture.
                                      Darn, I keep forgetting about the stupid PFC.
                                      • junktv
                                        • Nov 2010
                                        • 3065
                                        Took a break and put the rest of the caps in and it is still fluctuating.
                                        • tonybig10
                                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                          by tonybig10
                                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                          03-07-2025, 01:03 PM
                                        • slybunda
                                          Gemcon capacitor replacements?
                                          by slybunda
                                          taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                                          there are 2 caps which im looking to get replacements for.
                                          Branded as Gemcon
                                          single 100uf 16v 6.5mm x 11.5mm
                                          single 100uf 50v 8mm x 11.5mm
                                          lead spacing is around 3mm
                                          there is space for 16mm tall caps
                                          rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                                          the caps have...
                                          02-05-2024, 03:36 PM
                                        • burom
                                          Xbox 360 Xenon Modern Capacitor Replacements
                                          by burom
                                          I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                                          I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                                          06-07-2024, 05:10 PM
                                        • ziplock
                                          Abit BE6-II motherboard
                                          by ziplock
                                          Greetings,
                                          I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                                          I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                                          04-20-2025, 02:09 PM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
