Re: 17PW20 PSU Working but no power lights on LCD
If they are reading a higher capacitance they could be leaky and this could be a sign of failure.
I'd estimate ~85-90% of these Vestel PSU failures are due to them.
Yeah, they could have failed again. Just check them on a cap meter.Leave a comment:
ive changed them already, so they should be okLeave a comment:
See the tiny red caps near the big transformer. These tend to fail o/c.Leave a comment:
i have noticed on some repair kits there is a voltage reg 5v, and C901 cap i havent replaced them, so for the sake of a couple of quid im gonna get the C901 cap first which is 4.7uf @ 50v then see if that does it, cant see voltage reg being faulty if im getting 5v stable,
24v comes on, then when the set powers back to standby when the 3v isnt present it shuts down the voltages so all the other voltages are fine.
only caps that will be left to replace will be the little ones, 100uf 16v etc, im determined to try and fix this one because ive replaced so many parts im sure it will last a long time, but saying that theres only so much on one tv you can take.....lolLeave a comment:
The Vestel main board will do a self-test when first plugged in, if this fails it will go into "lock out" mode where it won't do anything. So, check the 24V peaks to 24V briefly. Honestly, these power supplies are so much trouble. I just replace them with a refurb 17PW15-8 or similar, those seem to last.Leave a comment:
BAD NEWS the goodmans has returned with similar fault, although ive found that its something to do with the 3v yellow cable that goes to the back light, any ideas what to check or replace on this circuit? ive noticed that when the tv is brought out of standby there is no 3v to the back light all other voltages are stable, but when there is the 3v's the tv works ok but then switches off after about half an hour, it sounds like a bad cap but ive replaced all the main capsLeave a comment:
37" up and running Saturday, just swopped main board and its working a treat
thanks guys for the input
gods knows how meny ive fixed now...thanks to this forumLeave a comment:
same as but saving up for one of rusmikes ones he does a very good price shipped to the uk.Leave a comment:
I need an esr meter really, I'm thinking about making one thoLeave a comment:
I tend to stay away from screen issue ones, like vert lines etc, so only had power board and invertor faults so far......thanks to this forum I've fixed all of them....o tell a lie I've got the 37" with main board that needs replacingI tend to find the easy fix ones i find cheap are always the hardest or unreparable ones,
although that 32in one i picked up a while ago with stand and remote for £30.00 was just 2 10uf or 100uf 450v caps on the inverter side so easy fix for once wish they was all that easy.
all but one tv cost me less than £55, and the one I bought for £80 cost more to fix than the others!
although that 32in one i picked up a while ago with stand and remote for £30.00 was just 2 10uf or 100uf 450v caps on the inverter side so easy fix for once wish they was all that easy.Leave a comment:
Picked up a 42" the other day with the same symptoms as the 32" so hoping it's the same fault....nice easy recap job!Leave a comment:
cool its nice when you mange to get a nonworking set up and running good luck with the 37in set.Leave a comment:
all caps changed on the power board of the 32" Goodmans, out of the 13 i changed there was one bulging at the bottom....capxon cant remember the uf, but just tested for half hour and it hasnt gone off or any thing so another one done, just waiting for the main board for the 37" which i have had a slip through the door so got to pick up tomorrow from post office so fingers crossed that should work if not ill be back to report!Leave a comment:
I've ordered the main board for the 37" and all the caps for the PSU on the 32" so I'll update when I've fitted and tested both TVs
Shame I didn't see the kit earlier cause I ordered the replacement caps for g-luxon caps yesterday, but ordered the Panasonic 15nf ones now, but will remember for future to look for the repair kits instead
Thanks tomLeave a comment:
Looks fine but...
http://www.ebay.co.uk/itm/17pw20v1-v...8#ht_500wt_971
Might end up cheaper as it has a few other parts too.Leave a comment:
will this do the 15nf ones?
http://www.ebay.co.uk/itm/PANASONIC-...item3a70f0a15fLeave a comment:
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
Assuming...7 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by semiRocketThe set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious... - Loading...
