Samsung PS50a410
    Re: Samsung PS50a410
    Originally posted by nickdablack
    Found the 19N60 from a local supplier. The info on the schematic labeled the SMD's as:
    RP858 - 10(2012)F
    RP816 - 22(2012)F
    I've been trying to google those figures, but no luck so far. I'll have to invest in some calipers to measure them.
    Maybe this? http://parts.digikey.com/1/parts/776...12t-1r0-f.html
    10 ohm and 22 ohm 1206 (2012 metric) resistors. I use a cheap £7 digital caliper from eBay to measure them. Resistors are very cheap though (~15 cents for 20), there's no harm in ordering some other sizes to be sure.
    Samsung uses metric measurements on their schematics. I'm not sure why, it's a sensible idea in theory, but the rest of the world still uses imperial for most electronics.
    • nickdablack
      • Apr 2012
      • 47
      Well so far its $18 worth of parts. (including $8 for a 10 pack of fuses). I will be very happy if that does the trick.
        8 bucks for 10 fuses...? Are they audiophile gold plated ones?
        • nickdablack
          • Apr 2012
          • 47
          Yeah they are a little pricey, but they were the best match on the site.
          • awyatt2
            • Feb 2012
            • 407
            • america
            try here on the codes look like maybe zeners
            http://www.marsport.org.uk/smd/mainframe.htm
            • nickdablack
              • Apr 2012
              • 47
              Turns out they were RP2012 package surface mount resistors. But I do appreciate the effort.
                Maybe your best bet would be a local electronics store. In the UK I can buy a pack of 10x T5A(250V) glass fuses from Maplins for £1.99.
                • nickdablack
                  • Apr 2012
                  • 47
                  I just ordered them with the other components. Half the local electronic stores have shut down. So it would probably cost me the extra $4 to drive to one that supplies the fuse I need.
                  • nickdablack
                    • Apr 2012
                    • 47
                    Bah.. Now Farnels cant deliver for a week. Oh well I will have to be patient.
                    • nickdablack
                      • Apr 2012
                      • 47
                      I have replaced all the components and no more shorts. Just waiting on the surface mount resistors. Hopefully should be delivered tomorrow. Then I will be ready to power it up.
                        Good luck! Not that you should need it. I wish you well.
                        • nickdablack
                          • Apr 2012
                          • 47
                          I should say that full credit should go to you Tom. You will hopefully be able to brag that you fixed a tv from the other side of the world.
                            Saving a TV from being dumped and going to waste is a fantastic feeling. I can't stop! I've repaired some 19 LCD TVs now.
                            • nickdablack
                              • Apr 2012
                              • 47
                              Yeah I am doing this as a hobby. For a while now I've been feeling bad that my years of Electronics study have been going to waste. And I do like the idea of saving good devices from land fill. I've been scouring ebay for more good candidates.
                                An addict in the making. I'm hoping to study Electronics Engineering in university in about 6 months.
                                • nickdablack
                                  • Apr 2012
                                  • 47
                                  Good luck. You should do well.
                                  Would you believe I ordered the wrong resistors. I found a local supplier so back to the shops for me in the morning.
                                  • nickdablack
                                    • Apr 2012
                                    • 47
                                    Replaced the parts and got it working for a good 10 seconds. Then a high pitched noise followed by the main fuse going and we are dead again. Back to fault finding.
                                      Hmm. Controller IC possibly damaged in the surge. Are the same components burnt? Did the display light up at all?
                                      • nickdablack
                                        • Apr 2012
                                        • 47
                                        The display ran for a few seconds. I'll pull out the board tonight and have a look.
                                        • nickdablack
                                          • Apr 2012
                                          • 47
                                          Found it. NT801S has shorted and exploded. It is listed as SCK20206LSY. Not too sure what that is. Looks like a capacitor, however the symbol on the circut diagram is not a capacitor. I am going to have to look it up. Any thoughts?
                                            09-07-2024, 05:50 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
