Acceptable Voltage Variance
  • dhack61
    • Aug 2010
    • 33
    I an working on a RCA L37WD12. I have a SMPS 1W power supply thats putting out 3.6V DC Standby. The spec calls for 5V DC What the normal variation you can expect on standby voltage?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Acceptable Voltage Variance
    I don't know if there is an official number, but for ATX power supplies, I believe it is +/- 5%.
    In any case, 3.6V is way too low for standby.
    Check the startup cap next to the SMPS for its capacitance and ESR values.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      More suggestions.
      1) Check the VCC of the SMPS IC to see if it matches the startup voltage compared to its datasheet.
      2) Check the DC voltage on the 5V output diode to see if it is 5V.
      3) If 1 and 2 are okay, then check the capacitor's capacitance and ESR (secondary section).
      • dhack61
        • Aug 2010
        • 33
        Originally posted by retiredcaps
        More suggestions.
        Thanks for the info. I found a Ceramic Cap soldered on the back of the board that was reading infinite both ways. Its a 220pF 250v Guiess they used it to regulate the voltage down. Gonna replace it and see if that gives me my 5v without it getting 12.8v standby. thanks again
        • cashkennedy
          • Aug 2011
          • 668
          If you test a capacitor with a regular multimeter on the resistance setting, then you will either see infinited resistance, or a very quickly asscending number that reaches infinite.
          The safety ceramic caps have very tiny capacitances (pico farads vs micro farads for the large aluminum caps), thus they can be charged by the voltage of your multimeter in micro seconds, once they are charged they show infinite resistance, so essentially it charges / becomes infinite resistance faster then the multimeter can detect.
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • x_orange90_x
            Samsung UN55KU6300F no standby voltage
            by x_orange90_x
            I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
            Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
            05-21-2025, 09:59 PM
          • Bad_IC
            Philips TV 37pfl5604h/12 no standby voltage
            by Bad_IC
            I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
            These are the voltages in some pins of IC fsq510:
            Vcc=18v
            D=320v
            Vstr=154v
            Unfortunately, I couldn't find the schematic
            What else could I check?
            Is it possible to provide standby voltage from an external source to allow the TV to turn on?
            Thank you​...
            11-08-2024, 01:07 PM
          • brock-s
            Asus GL503GE 3.3 standby voltage low
            by brock-s
            An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
            Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
            Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
            07-13-2023, 03:43 PM
          • reessi
            JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
            by reessi
            I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
            You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
            Years ago it had some bulging caps...
            04-26-2021, 11:42 AM
