VIZIO LCD Problem
  • xjimtx
    • Apr 2012
    VIZIO LCD Problem
    I was hoping someone could help diagnose a problem I am having with my TV. It is a VIZIO VW46L FHDTV20A. At random times I get 4 evenly spaced black lines running horizontally across the screen and then half the screen vertically (always right to left) fades to black. In about a minute its back to normal, but 5 min later or up to several hours later it happens again. Really I'm mostly interested in knowing if it is something that is worth repairing or should I be looking into a new tv
    Appreciate it
  • shepp
    • Mar 2012
    • 377
    • England
    Re: VIZIO LCD Problem
    have you inspected the boards? as in power board etc
    • tibimakai
      • Jan 2012
      • 3680
      I have a similar issue, but mine gets a lot worse after it is warmed up.
      What others suggested is to try cleaning or reseating the ribbon/flex/ cables at the top of the TV(there are four of them). Those brown clips fold down, then you can lift the flex cables out. You can try reinstalling a couple of times, maybe that is enough.
      I'm at that stage, waiting on a cleaner spray that I have ordered. If it won't fix it then most likely I need a T-con board.
      My thread is VW42L but I made a mistake in the title.
      https://www.badcaps.net/forum/showthread.php?t=19733
      • xjimtx
        • Apr 2012
        No I haven't, I'm afraid that's beyond the scope of things I do (if it was a computer that be a different story). I was hoping from the description I gave someone would say that they have seen/heard of the problem before and either its a simple repair and would pay to have it fixed or that I'm screwed and should start saving for a new one
        • xjimtx
          • Apr 2012
          Thanks for the reply tibimakai, going to check out your thread now
          • cashkennedy
            • Aug 2011
            • 668
            Your problem could be the t-con, could be some thing else. If its the t-con you could probably replace it yourself with one from ebay for around 30-80 dollars (depending on the cheapest one listed when you look). And it would take about an hour to do at most. Whether that makes you interested in replacing the tv, or trying to fix it is up to you. The tcon has 2 or 4 flexible ribbon cables which usually you pry up a long thin strip holding them in (the strip rotates sorta) and then you can remove the cables and clean them lightly and reinsert them, make sure they are perfectly straight, ligned up, in any notches that seem normal, and as deep in there as they were to begin with (as deep as they will go).
            Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
            • rajbot
              No Power problem with Vizio E60-E3
              by rajbot
              Hi all:
              I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
              I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
              On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
              03-22-2023, 08:09 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Pinky Deepak
              Vizio M60-C3 Left Edge problem
              by Pinky Deepak
              I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
              Here's a video of both the issues: https://youtu.be/hMqc760nB3o
              09-27-2024, 05:11 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
