have a vizio va320m with no audio. Picture is perfect but do not have any audio coming out of the tv no matter what input im on.
VA320M No audio
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
Assuming...7 Photos -
by WayOfTheRoadHello, everyone. A neighbor was throwing this TV away for "not turning on" so I asked for it and they gave it to me for free since Vizio gave them a new TV under warranty.
I'm pretty proficient with electronics in general but this is the first TV I've ever tried to fix. I strongly suspect bad LED lights but figured I'd post some info and see if those of you more experienced with TVs can confirm my suspicion before I move forward. Some photos and measurements below:
The power supply only has two outputs, one output cable going to the main board and the other... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by i_am_patchHi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
04-30-2024, 08:20 PM -
- Loading...
