Vizio Plasma 50HDTV10a problem
  • runyonwc
    • Feb 2012
    • 14
    I'm trying to fix my plasma tv that has a white vertical column in the center of the screen. The rest of the screen is black but I do have sound. Does any one have any experience with this or have any idea what it could be?
    Thanks!
    Walter Runyon
    Re: Vizio Plasma 50HDTV10a problem
    I have heard this may be caused by a failed Y buffer but to me it would seem more like control board or X buffer. You would do well by taking the back off your TV and photographing it so tests can be indicated.
    • runyonwc
      • Feb 2012
      • 14
      I tried the other night to desolder one of the chips on the ysus board to see if it was burnt on the bottom but I wound up breaking it. So it definately needs a new ysus board. The ysus wouldn't cause this would it? I unplugged the zsus and the screen got dimmer so that seems to be working. I also did not find any bulged caps on the Zsus or Ysus, nor did I find any blown caps.
      Should I still take a picture with the back off with no YSUS board?
        What chip did you desolder from the Ysus board?!
        You may as well replace the Ysus board, I'd be 98% confident (**made up figure) that it's not causing this problem.
        • runyonwc
          • Feb 2012
          • 14
          I tried to desolder one of the big chips with the heat sink on it.....so would you still like me to take a picture of the back of the tv or will it tell you nothing without a working ysus board?
            Can you post a picture of the board you desoldered / attempted to desolder the chip from?
            • runyonwc
              • Feb 2012
              • 14
              • rpgruss
                • Jan 2012
                • 124
                Per http://blog.coppelltvrepair.com/2010...-lines-in.html, you likely need a new buffer board. Unfortunately, that y-sustain is very expensive, if you can find one. Maybe you can find a new IPM chip to repair it. If I see anything I'll post it up here.
                • rpgruss
                  • Jan 2012
                  • 124
                  I spoke too soon. Assuming you have a 6871QYH039 A/B/C board, which it looks like but I can't make out from the picture, you need this chip: http://www.ebay.com/itm/Sanyo-Module...1#ht_500wt_969
                  39.85 plus shipping if you are in the US.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    To me this is a problem with either the X-Main or the Logic Main boards. The Y-Main addresses the rows, the X-Main addresses the columns. I don't think it is the main (signal) board. runyonwc, does the color and intensity of the central bar change if you change signal sources?
                    PlainBill
                    • runyonwc
                      • Feb 2012
                      • 14
                      The screen does not change if I change signal sources. Do you think this TV is worth repairing? Right now it seems I will have to replace 3 boards (YSUS, Main, and X-board)
                        A new 50" plasma is around $600, the parts will probably cost $150 total, do the math.
                        • runyonwc
                          • Feb 2012
                          • 14
                          I didn't realize the parts would be that affordable!
                            The main logic is most likely the cause of this problem. You'll also need a new IPM or a new Y-sustain. Fix the Y-sustain first, before attempting to diagnose the main fault. The Y-sustain is unlikely to be the cause of the problem you are seeing.
                            • runyonwc
                              • Feb 2012
                              • 14
                              Tom, did you read the link to coppell tv blog? It mentions the problem being the Y buffers, what do you think about that? Possible?
                                That's what I initially thought, because I'd heard it before. But it seems very strange for a Y-buffer failure.
                                Does this TV have two Y-buffers, or just one?
                                • runyonwc
                                  • Feb 2012
                                  • 14
                                  It has two. I guess it couldn't hurt to do the resistance tests mentioned in the blog??
                                    Well, when you replace or repair the Y-sustain, try running it with just one and see if you get half a picture back.
                                    • runyonwc
                                      • Feb 2012
                                      • 14
                                      Will do!
                                      • runyonwc
                                        • Feb 2012
                                        • 14
                                        So I put in a new buffer board and used ysus. The lines in the middle are gone now but I hear a clicking coming from the ysus and the screen kinda flashes on and off with the clicking.
                                        Any ideas?
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
                                        • renech
                                          panasonic TH-42PC77U plasma television half screen problem
                                          by renech
                                          hello,
                                          I hope someone on this forum can assist me.
                                          I have a panasonic TH-42PC77U plasma television.
                                          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                          I have read some posts that suggest the problem is related to the boards on the left...
                                          12-12-2022, 06:53 PM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
