Ilo LCT32HA36 weird issue
  • SnipesXxX
    • Sep 2006
    • 7
    Got a Ilo LCT32HA36 LCD TV that had no power. Opened it to find most all caps on the PSU leaking, bulging. Replaced them now I get power. However it cycles on its own without the press of any buttons. It acts like 2 sec to black and then shuts down on its own and powers back on by itself. Whats really weird is if I hold any of the buttons(except power) and plug it in it powers on and stays on(display and all). When I release whichever button I'm holding it shuts down and starts cycling again.
    Is this likely the mainboard?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Ilo LCT32HA36 weird issue
    Some suggestions
    1) If you disconnect all the boards, does 5V standby stay steady?
    2) If you "jump" the power supply on, do the secondary voltages stay steady? Something like this (not your TV, but the concept is the same) ...
    https://www.badcaps.net/forum/showpo...2&postcount=56
    3) On the main board, see if there are voltage regulators and check to make sure they are outputting the correct voltage.
    4) The eeprom on your main board might be corrupt?
    5) Top down view pictures (both sides) of your boards help us help you. Follow the instructions in my sig file exactly.
    --- begin sig file ---
    --- end sig file ---
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
    • ugamazing
      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
      by ugamazing
      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
      04-10-2024, 08:06 AM
    • lukkihapsi
      Asus Vivobook X515JA Weird Boot Issue
      by lukkihapsi
      Asus Vivobook X515JA Laptop
      Issue :
      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
      Tried :
      Cleaned inside for dust, applied fresh thermal paste. No Change!
      Removed keyboard, Trackpad, fingerprint sensor. No Change!
      Removed Internal SSD. No Change!
      Updated BIOS to latest version. No Change!
      Removed battery and pressing power button for 1 minute. No Change!
      Weird Part :
      Upon turning laptop ON, screen lights up - stays black,
      I...
      07-07-2025, 12:07 PM
    • Spider1211
      Weird but interesting issue with DELL 3542 (intel mb 13269-1)
      by Spider1211
      Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
      Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
      Backstory:
      Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
      Power supply draw:
      Voltage: 19.40V
      Amp draw: 0.006 - 0.007A
      Amp draw...
      04-07-2021, 03:21 PM
    • tommygun26
      Hp 6510b weird issue
      by tommygun26
      Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
      02-26-2023, 06:00 AM
