dgtec dg hd-5370(no sound)
  • Amraks
    • Nov 2011
    • 725
    I got this HD STB from a garage sale today.
    Got home and tested it, played with every setting possible, then opened it up, Noted there was no bad caps.
    Now I'm confused to as what the problem could be?
    would it be cold solider joints?
    Which parts should I be looking over?
    Thanks guys in advanced, this site has be good.
  • Amraks
    • Nov 2011
    • 725
    Re: dgtec dg hd-5370(no sound)
    Oh also forgot to note there is also a faint sound on some of the HD channels but not the standard def channels.
    Also I have recorded some TV with it and played it back on the computer it has sound.
    • Amraks
      • Nov 2011
      • 725
      Photo of the board.
      • Amraks
        • Nov 2011
        • 725
        Ok I have sound but its very faint. did a bit of soldering.
        Would this be a capacitor causing this?
        If so which ones?
          So... for those of us who don't mind read, what is the problem?
          • Amraks
            • Nov 2011
            • 725
            Very faint low volume, thats is the problem.
            • Amraks
              • Nov 2011
              • 725
              • Amraks
                • Nov 2011
                • 725
                Where them arrows are pointing to the suspect bad caps, How is it possible to have sound when these are bad?
                Also tested the HDMI output and it all works fine.
                • Amraks
                  • Nov 2011
                  • 725
                  replaced the caps sound clearer but still faint.
                  anyone with any ideas?
                    Could be the analog switch (the 14/16 pin IC next to the caps) or a setting in the menu has volume set low.
                    • Amraks
                      • Nov 2011
                      • 725
                      Can't be any settings I have done a factory reset and found all the sound settings. fiddled and fiddled.
                      Would it be safe to pull a IC out of any STB?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Remote troubleshooting is a Garbage In - Garbage Out situation. Post a decent sized picture (a .jpg file close to 2000 x 2000 pixels) by using 'Manage Attachments' - below the text entry area - and we will have a fighting chance to help you. The fact that changing capacitors helped is a clue, but without adequate pictures it's hard to make valid suggestions.
                        PlainBill
                        • Amraks
                          • Nov 2011
                          • 725
                          Ok thank you I may have to borrow my dads digital camera when I see him next my digital cam isn't very good.
                          • Amraks
                            • Nov 2011
                            • 725
                            Anyone got any idea?
                            Thanks in advanced, I'm really wanting this set top box to output sound.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Well, this may be fairly straightforward. I have only a Wikipedia knowledge of SCART, but let's see if I understand the situation. Please correct any errors in these statements.
                              1. Both SD and HD video signals work.
                              2. HD audio is faint, SD audio is missing.
                              3. Does 'tested the HDMI output and it all works fine' apply to both SD and HD video and audio signals?
                              I see 5 ICs in the general area of the SCART connectors. Two of them are definitely 16 pin dips, one is partially obscured by a cap and may be 14 or 16 pin, one is a standard form factor 8 pin, and U5 seems to be unusually wide. What are the part numbers of those 5 ICs? I note that analog signals are on the first few pins of SCART connectors, I take it that is the right end of the connectors in the picture.
                              PlainBill
                              • Paul678
                                • Nov 2011
                                • 402
                                Have you tried audio signal-tracing with an oscilloscope,
                                starting from the speakers, and working your way back from
                                there?
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  PlainBill
                                  HDMI is perfectly normal, audio acts like normal.
                                  its on scart connectioning it is faint.
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • LEECH666
                                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                    by LEECH666
                                    Good day ladies and gentleman!
                                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                    01-19-2024, 05:46 PM
                                  • Christos Tsiligiannis
                                    Marian Trace Alpha sound card repair help
                                    by Christos Tsiligiannis
                                    Hello to the forum.
                                    My name is Christos, I am new to the forum here and i am posting from Greece.
                                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                    11-18-2024, 05:26 AM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 02:30 PM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
