Got this for cheap. I initially thought it was a bad hybrid, but then I noticed the power board had 7(!) bad capacitors on it. 6 of them are 3300u/10V Samwha WB and one is a 680u/50V Samwha WB. I replaced 4 Samwha WB in my 42" LG LCD I got from the dump - so the WB series seems very problematic.
Upon plugging in, the inrush limit relays click, the screen briefly flickers white, then a whining sound is heard, the relays click back and the TV switches off. The cycle repeats about once every 2 seconds. Interestingly, the status LEDs on the control board fade out when the relays click back - they don't go off abruptly.
Using my Atlas ESR60, all the bulged caps test bad (>0.03ohm ESR for most.) One, which was not that badly bulged measures 1.51ohm ESR!! So very clearly failed. I tested the other caps on the board that weren't bulged, and they seemed okay.
To verify it was not either sustain at fault, I disconnected both Y and Z sustains and the TV continued clicking, except this time the screen remained completely dark which I expected.
As the plasma panel lights up (quite brightly too, if only for half a second), I assume it still has its gases, and the hybrids are good. I will check the fuses later on the sustains. And I'll try and post pictures later - currently battling with the SD card reader. Ugh.
To PlainBill, master of LG, how much experience do you have with this particular TV? Have you encountered this issue before?
