scetre 32 LCD - works for 5 minutes then loss of picture
  • doanh
    • Feb 2011
    • 35
    Man, these LCD and Plasma TVs are just plain problematic.
    My sister 32 inch LCD sceptre has a bad solder joint I think.
    It comes on with from red light to blue light. Everything works for about 5 minutes and then the screen goes dark. blue light stays on.
    I unplugged the TV for about 10 minutes and it comes back on the the picture goes away again.
    Changed out the inverter board but that does not appear to fix the problem. how do I determine if the T-con is working properly or not?
  • PlainBill
    • Feb 2009
    • 7034
    Re: scetre 32 LCD - works for 5 minutes then loss of picture
    By replacing it with a known good board.
    With all due respect*, you are wasting a lot of money with your troubleshooting approach. Does the sound work after the screen goes dark? The tcon should not affect the sound. Do the backlights go out (there is usually some light leakage even if the screen is black).
    ABOVE ALL, are the output voltages out of the power supply correct after the screen goes dark?
    PlainBill
    * Not much.
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • Davidhames
      KDL-70R550A Peeled off LCD Tabs on left side and perfect picture for 5 minutes
      by Davidhames
      Hi Guys,
      Thought I might try and seek advice on an issue I am having, I got this SONY tv for free that was having some dark greenish colouring, I replaced the T-CON and too my suprise the TV would not boot - I would get 5 blinking red LED lights. I dug deeper into this forum and someone mentioned the fact that it might be the tabs that connect to the LDC panel, and peeling them off should bring back a clear image. I tried this on the side of the T-con that was causing the tv to not boot when plugged in (left) and wow a perfect picture and was booting up fine! All was well and good...
      02-23-2022, 08:21 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Zonzi
      Neptune mixer model 611 - Works for a few minutes then fades out and distorts
      by Zonzi
      Hi there !
      This is my first post out there, glad to be part of the community.
      I was gifted an old analog mixing unit (from the 70s) by a good friend. It's a Neptune Audio Mixer model 611, 6 channel mixer with :
      -6 XLR inputs wired hot to 3, and 1&2 to ground (which is already a weird start. You can see this in Picture 3, and all sockets are what I understand to be common ground, as there's a long wire connecting all XLR grounds together. Besides, all Hot are connected to the other pins via a cap with the marking 24 102k)
      -6 unbalanced...
      02-16-2023, 06:28 AM
    • kekelen
      HomeWizard Energy Display (no backlite)
      by kekelen
      I’m a total beginner at electronics repair and have very limited knowledge about components, so please bear with me.
      Problem:
      The display on my HomeWizard Energy unit started flickering for a few minutes and then went completely dark. The backlight no longer works, but I can still faintly see the text on the screen under good lighting.
      I tested the display itself on a drive control board (used for PC/Raspberry Pi), and the screen works fine — so the issue seems to be on the main board.
      What I’ve tried so far:
      • Checked for
      10-23-2025, 03:17 AM
