Re: 42inch Touch Screen wont power on
Sorry guys i have been away on business and just got back got the resistor and going to try it tonight.
If the power supply operates correctly which i think it will, how can i go about identifying what this main board is so i can seek a replacement ?
As i have tryed to google to numbers on it and returned no results.
Thanks Guys
Get a 1/4W (quarter-watt) 5% resistor of any value from 2.2k (2200) to 4.7k (4700) ohms.Leave a comment:
Do you have a 2.2k - 4.7k resistor; or can you acquire one (e.g. from RadioShack)?Leave a comment:
ON the main board i followed the power button switch and it has 4.49 volts and drops to 0v when pressed. However on the opposite side where pin10 (on the power supply) connected to the main board we are seeing no 0v drop.
Does this determine there is a fault with the main board? is there a way i can short pin 10 to see if the power supply fires up to indeed confirm this theory?
Would you like pictures of the main board?Leave a comment:
This is located on the Powersuply IC101 located behind small transformer parallell with the large transformer. inbetween lrage heatsincs.Leave a comment:
Sorry guys i did this with the cables pulled out because i thought when the relay clicked it would turn the power off...
i redid all the tests and the volts are slightly diffirent
CN04
1 2.6mv
2 5v
3 0.53v
4 0
5 0
6 0
7 .5v
8 .5v
9 5.24 v
10 4.49v
I tested for volatage drop on pin 10 when pushing on off no change voltage stayed solid.
CN03
1 4.2mv
25.2mv
CN06
1 .5v
2 .5v
3 Blank
4 Blank
5 gnd
6 gnd
7 gnd
8 gnd
9 -.4mv
10 -.4mv
11 -.4mv
12 -.4mvLeave a comment:
Is this IC101 on the board? When talking about components, please always list where it is on the board via pcb identifier so we know where to look. The more info you give, the less we have to guess and ask for clarification.Leave a comment:
We are still getting 5V SB. Pin 10 is power on/off.
If you hit the power off/on button, see if pin 10 drops to 0.0V. It should change between 0.0V and 2.94V if the main/logic board is working properly.Last edited by retiredcaps; 01-02-2012, 12:54 AM.Leave a comment:
okay guys sorry re tested everything, found some unusal results to say the least.
CN04
1 0
2 -351.7 mv
3 -351.7 mv
4 0
5 0
6 0
7 -349mv
8 -349mv
9 5.24 v
10 2.94v
However with the power off doing a continuity test and touching a common ground pins 1-8 all show as a ground????
CN03
1 4.2mv
25.2mv
CN06
1 7mv
2 4.2mv
3 Blank
4 Blank
5 gnd
6 gnd
7 gnd
8 gnd
9 .4mv
10 .4mv
11 .4mv
12 .4mv
This again is unusal pins 9-12 show as a ground aswell ?
have uploaded pictures let me know where to go from here guys.Leave a comment:
So, I've been away for a while from this thread...
Bring me up to now:
Have you got any output voltages, at all, on the power supply?Leave a comment:
okay so i re esembled it and tested pin 3 and 2 and i got 14.54 vLeave a comment:
Hmm, I think from looking at the hot side data and the picture in post #20, I would have expected continuity between more pins in the primary and tertiary.
I'll see if tom66 and PlainBill concur or not. I could be looking at the wrong transformer too.
You might as well test "in circuit" the yellow transformer below the big one. You don't have to desolder, but we would like to see the same "all pins" combination test.
Should i test the mosfets?Attached FilesLeave a comment:
You might as well test "in circuit" the yellow transformer below the big one. You don't have to desolder, but we would like to see the same "all pins" combination test.Last edited by retiredcaps; 12-30-2011, 04:44 AM.Leave a comment:
It was very hard to get the reading of resitance it seemed to be very tempermentalAttached FilesLast edited by epicfatigue; 12-30-2011, 04:16 AM.Leave a comment:
Still missing a whole bunch of data. See post #89 again for the pattern and compare to your xls file.Leave a comment:
1) Datasheet is at
This is a FET/SMPS. Refer to figure 3 for the pinouts.
2) Pin 3 is Vcc and pin 2 is GND. Measure the resistance between these 2 pins. Report the reading.
3) According to the datasheet, when Vcc reaches 12 V DC, it starts working. After we tell you to reinstall everything, check Vcc to see if it gets to 12V DC.
4) Page 13 has a schematic.Leave a comment:
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by AJ847.63eHi All,
We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling... -
by hotglyAfter upgrading the factory 128Gb SSD to a 512Gb WD_Black SN770M, this surface pro lost touch on screen, no touch in windows or in UEFI.
The Human Interface Devices did find touch and stylus but it shows Disabled in windows device manager.
I am not sure if this is a bios problem or hardware problem, already tried reinstall and reset from windows, not working. And now trying to clean/reset the bios.
Computer model is: Surface Pro 9, i5, 8GB memory, 128GB
Serial number: 0F00S2Y22353BF
Intel(R) ME Code Versions:
BIOS Version 12.200.143
MEI Driver...-
Channel: BIOS Requests ONLY!
by Yehuda170original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
with original broken screen i can see in device manager touch screen in human interfaces
but with the new screen it's not showing in device manager
is it lenovo blocking it? is it driver missing?
I²C is a headache -
by grimacelordHello,
I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...-
- Loading...
