22pfl3504d/f7 tv shuts off
  • mcross
    • Sep 2011
    • 201
    I am working on a 22pfl3504d/f7 tv it just shuts off after about 3 mins. no signs of bad caps as far as bulging ect,. Any ideas? has a ba9170f0101 1 power board in it
    Mike
  • huzo
    HP Omen shuts down when loading OS
    by huzo
    The model is 15ec-1061nm
    Board number is DAG3EDMB8D0​
    SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
    10-29-2024, 12:05 AM
  • berriferous
    Samsung PN43E450A1FXZA (Plasma) - Display up for 4 mins, then shuts itself down
    by berriferous
    Set was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
    I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
    If I unplug the power feed to the X/Y board (LJ92-01854B), the...
    12-16-2024, 09:58 AM
  • Giggle2562
    Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
    by Giggle2562
    I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
    The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
    Here's what I've tried so far:
    • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
    • The laptop shows an image on the internal display for a few seconds before it shuts down.
    • I tried swapping the LCD panel with a known good one.
    • I tried swapping the LCD cable
    11-06-2025, 12:36 PM
  • riko 656
    Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
    by riko 656
    I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
    Laptop Model:
    • Model: Lenovo Legion Slim 5 16APH8
    • GPU: NVIDIA GeForce RTX 4070
    • Main BIOS chip size: 32MB
    • VBIOS chip size: 16MB
    Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
    What I Have Tried So Far:
    1. I
    11-04-2025, 05:14 AM
  • brav1ez
    ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
    by brav1ez
    I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
    I’ve tried:
    - CMOS reset
    - Removing the SSD/HDD
    - Reseating RAM (removing each stick individually stops boot completely)
    - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
    With...
    09-07-2025, 10:47 AM
