3" black line in middle of sanyo plasma tv
  • dandan62
    • Nov 2011
    i have a sanyo dp50747 with a 3"inch black line on the right side and a 1/4" snowy line in the black line goes from the top to the bottom i want to repair any ideas of what it might be
    thanks
  • rayrod81
    • Oct 2010
    • 205
    Re: 3" black line in middle of sanyo plasma tv
    Most likely not repairable as the IC that controls the addressing is bonded to the ribbon that connects the lower buffers to the panel. This ribbon is built in to the panel and not repairable without specialized equipment.
    • dandan62
      • Nov 2011
      ok is there any other thing it could be just to try and see if i can get it working
      • dandan62
        • Nov 2011
        where abouts can i order the part for this tv
        • PlainBill
          • Feb 2009
          • 7034
          Look at the back of the plasma panel for a part number. Google it.
          PlainBill
          • dandan62
            • Nov 2011
            ok do you know what whould cause this and would it be able to be fixed with the tools needed even if the ribbon is boned and is the board that is on it now fixable in any way
              Sometimes the X buffer board goes out, but in most cases it is the panel. The panel is 50-75% of the price of a new TV, so it's often not worth it.
              • PlainBill
                • Feb 2009
                • 7034
                Here is what I understand based on accounts from the experts. The X driver ICs are electrically bonded to the flex conductor using a non-solder process; they are in thermal contact with the heat sinks at the bottom of the panel. Sometimes a driver IC will fail, sometimes the bond will fail. No one has reported successfully replacing a driver or repairing a failed bond. The have reported that attempting to remove or resolder the driver results in destroying the flex conductor.
                Now, it is (for the most part) a free world. You are welcome to research the problem, attempt to replace the IC, or jury-rig an alternative solution. The Electronics Repair field is full of successful repairs of non-repairable items, but in this case I can't offer any encouragement. I don't know where you would buy the ICs, the material used to bond them, the material which can unbond them, or even where to look.
                I note that the TV is at least two years old, and has a typical 1365 x 768 (720P) resolution; at 460 watts it's also a power hungry beast. The current version is available at Walmart for less than half of what you paid for this one, but I don't recommend it. You probably won't even have to wait until Black Friday to get a 55" 1080P LCD TV for under $700.
                PlainBill
                • rayrod81
                  • Oct 2010
                  • 205
                  You can try to replace the bottom buffer and see if you get lucky as they are inexpensive. In the end you will most likely need a whole new panel. For this TV you can probably find a replacement screen for $300-$400 after all is said and done. Considering you can buy a name brand (Samsung, LG, or Panasonic) plasma 720p 50" plasma for $650 it is probably not worth the repair. You could even go for the cheap Walmart brands (Sanyo, Element, RCA, or Viore) and get into the $500 neighborhood but I wouldn't recommend it.
                  • Maniackk
                    Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                    by Maniackk
                    Device: PocketBook InkPad 3
                    Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                    I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                    I would appreciate help identifying this component.
                    Measuring the loose component with a multimeter gives 5.84 MĪ© in both directions, while the one still on the board shows no measurable...
                    05-16-2025, 08:53 AM
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • fibcom999
                    LG OLED 55EG920V Black Screen with one line
                    by fibcom999
                    Hi guys, I have aquired a LG 55EG920V for very small amout of money.
                    I have jumped the Power on, DRV_ON and 3,5v pins just for the screen to show a black screen with a green line offset to the left.
                    Connecting everything together, shuts the tv off automaticlly after a couple of second( LG protection?)
                    Tried with a spare MB and the original, both the same results.
                    But if i unplug the 12v rail to the tcon or the larger LVDS to tcon, the tv turns back to the one line and dosent shut off.
                    Could this be a tcon issue or something...
                    06-17-2023, 06:18 AM
                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                    09-12-2024, 02:00 PM
                    MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                    This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                    09-12-2024, 01:58 PM
