RCA 32V434T chassis ATC010A
Re: RCA 32V434T chassis ATC010A
DMM Diode test
B(+) E(-) .041
B(-) E(+) .041
DMM 200 Ohms test
B(+) E(-) 43.8 (ring tone)
B(-) E(+) 43.8 (ring tone)Comment
[QUOTE=PlainBill;197410]It appears to have a base-emitter short; if so, it's bad. What is the base-emitter resistance?
PlainBill[/QUOTE
H.O.Transistors come in two flavors. This flavor has a low resistance e-b. The only important resistance check is C-E.
More important, when the H.O.Transistor is removed is the B+ voltage. Does it return to normal? If it does the problem is downstream from the flyback transformer.Comment
Still removed from circuit.
DMM Diode test
C(+) E(-) .OL
C(-) E(+) .497
DMM 200-200K Ohms test
C(+) E(-) OL.
C(-) E(+) OL
DMM 20,000K Ohms test
C(+) E(-) OL
C(-) E(+) 655 and slowly ticks down by 1
DMM 20M Ohms test
C(+) E(-) 7.35
C(-) E(+) 1.71Comment
Back to repair :
I soldered Q405 back in (I'm still not sure if it's good) and reassembled to test the run power suppy.
Set didn't turn on, lost 5V standby. Removed IC804 for testing.
LED test fine but, the phototransistor is shorted.
Would this one be a good replacement?
http://search.digikey.com/us/en/prod...17-5-ND/457901Comment
Back to repair :
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Did you pull the Horizontal output COMPLETELY out of the board? If so, and you are measuring .044 B-E in both directions, that transistor is bad. If you only unsoldered the collector, then you are probably measuring the horizontal drive transformer in paralell with the emitter-base junction.Comment
low resistance B-E and E-B.Comment
I gotta stop posting before I have had my coffee!Comment
Replaced IC804
Applied power: no click from relay K802, no 5V STB
Following the guide on page 22 of RCA ATC010 Training Manual.pdf
1) IC860 pin(8) DC voltage 160.7
2) IC860 pin(1) DC voltage 9.54
4) IC860 pin(4) DC voltage 0.66
Since I've already replaced IC804, guess I have a problem with the feedback circuit off the 5V STB supply.
Since I don't have 5V STB on the Control Board (front panel buttons), I pulled T860 for testing.
Blue Ring tester: DMM Ohm's set to 200
pins 1&2 two steady red lights 00.8
pins 3&5 three steady green lights 2.9
pins 6&10 no lights at all 00.6Last edited by cmj21973; 12-14-2011, 10:14 AM.Comment
Latest trash/recycle find might yield EI ferrite core to rebuild T860.
Length, width, and height are a match. Will know about the center post after a 2 day acetone soak.
Meanwhile, I need to clean the magnet wires, 4 coils, so I get measurements.Comment
Okay, I've finished rebuilding T860.
Before: After:
pins 1&2 two steady red lights; 00.8 pins 1&2 three steady green lights; 00.7
pins 3&5 three steady green lights; 2.9 pins 3&5 three steady green lights; 2.5
pins 6&10 no lights at all; 00.6 pins 6&10 one red steadylight; 00.6
Next step is to test it out of circuit, to measure the secondary voltage ouputs.Comment
I soldered the rebuilt T860 back in placed. Was only getting about 76VDC on pins 5&3 (primary coil).
Found the negative solder pad for C861 had popped loose. Made a new pad, to bridge the solder traces, and solder it in place.
5V STBY power restored.Comment
With the 5V standby opperational, I followed the "Run Power Supply Troubleshoot".
1)With C-E of Q861 shorted, applied AC power and measured IC801 pin4 = 32.8VDC steady.
2) Unsoldered pin 1 of IC801 and measured DC voltage on pad = VDC > 120VDC
3) Resoldered pin1 of IC801 and checked secondary power supplies. I used the voltage test points listed on page 11 of service manual.
TP 1) 130V @ D882 = 133.5
TP 2) 130V @ L801 = 133.5
TP 3) 33V @ R826 = 33.9
TP 4) 12V @ D820 = 14.0
TP 5) 12V @ L807 = 10.0
TP 6) 9V @ pin3/IC091 =10.0
TP 7) 5V @ pinOUT/IC090 = 5
TP 8a) 5V @ L851 = 5.1
TP 8b) 5V @ pin3/P001A = 5.1
TP 9) 1.8V @ pinC/Q201 = 1.8
TP 10) 1.8V @ pinc/Q203 = 0
TP 11) 3.3V @ pinE/Q080 = 3.5
TP 12) 208V @ R505 = 133
TP 13) 14V @ D404 = 0.4
TP 14) -14V @ D405 = -0.3
TP 15) 12V @ R1301 = 8.7
TP 16) 230V @ R505 = 133Comment
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...09-07-2024, 03:10 AM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...09-07-2024, 03:10 AM
Samsung LED LCD TV Chassis U57E U57F U56G Schematic
Chassis: U57E
Model : UE40D500*BW
UE26D400*BW
UE32D400*BW
Chassis: U57F
Model : UE22D500*BW
UE19D400*BW
Chassis: U56G
LE32D400E1W
LE32D40*E2W
LE40D50*F7W
UE26D4003...-
Channel: Schematics and Boardviews
11-05-2024, 04:00 AM -
by carlucciLenovo thinkpad T15 Gen2
Board: NM-D352 rev.: 2.0
type 20W5 S/N PF-3TGB08
Symptoms: pressing power on, fan spins up but no POST, never getting to BIOS.
I already replace bios without sucess. Can someone give me a tip ?
Regards,06-06-2025, 05:33 AM -
Samsung UAD6400U UAD6600W LCD TV Chassis U69A Schematic...
11-05-2024, 03:56 AM -
- Loading...
