Chimei DTC-37MK - solid red light
  • VaNS
    • Oct 2010
    • 9
    So, I have this 37" LCD TV that just stopped working. I can't seem to power it on via Panel or Remote (by that I mean, trigger it to power on). I'm not sure if it's in standby mode, but when plugged in it only gives a solid red light in the front panel.
    it seems this LCDTV shares the same qualities as a Maginnovision, Element.
    Apparently the Mainboard was/is notorious for shorting if you plug something into a VGA port. So, I figured.. replace the mainboard and this being said I ordered a whole control box from shopjimmy ... plugged it in andddddd
    same problem. solid red light. sooo this has be a bit baffled. Maybe LCD Panel completely dead? I was thinking but even if it was it would still attempt to power up wouldn't it?
    it almost seems like it's something very simple that I'm missing.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Chimei DTC-37MK - solid red light
    Pictures.
    The obvious test is to determine if the main board is generating the signal to turn on the main power supply (since you have a red led, the standby supply is good). The signal is probably labeled PS_ON, or something similar.
    If you expect any more help, take three pictures - one overall shot of the back of the TV to establish where everything is. A second shot of the power supply, showing the output connectors. And a third shot of the main board. Sharp and well lit is important.
    For best results make the pictures at least 1000 x 1000 pixels, but not over 2000 pixels. Attach them using 'Manage Attachments' - below the text entry area.
    PlainBill
    • VaNS
      • Oct 2010
      • 9
      Pictures.
      PlainBill
      Ok, I'll look around for it. I'll be doing it with the original control box as I don't want to mess with the warranty on the one I just ordered.. which is said to be pulled out of a working LCDTV (but who knows).
      I've pretty much torn the LCDTV apart right to the panel for testing. (I'm not great with a multimeter but I know a bit)
      Any help on this is appreciated and thank you in advance as I've seen you help a few people on this site with their issues.
      • VaNS
        • Oct 2010
        • 9
        Attached are.. well the frame.
        connectors that lead into a serial port of some sort which connects to the mainboard.
        the inverter and the mainboard.
        I took a picture of the connector that leads to the mainboard from the power supply. I couldn't find PS_ON but would any of these be it? I took this picture through a lit magnifying lamp so if you need any close close ups feel free to direct me.
        this is all a learning experience for me.
          It looks as if that Panasonic cap just down from the main output connector is bulged.
          I've dealt with this supply before with the same problem. The fault was the uppermost two capacitors next to the grey transformer. But you have replaced them.
          Also something to check: While it is plugged in, try pressing down on the main board, near the input connectors, and seeing if the TV will then switch on.
          • PlainBill
            • Feb 2009
            • 7034
            Usually at this point I'm complaining about the poor pictures; these are excellent. You deserve special recognition for the last one.
            5VSB should always be live (5 volts) when the power supply is plugged in; STB is the control line. Because they call it STB, it may turn the power supply off when high - I've encountered that a few times.
            And note tom66's comments.
            PlainBill
              PlainBill
              This power supply is very odd. It seems to generate 5V, 12V etc. all while in standby. When turned on, the 24V rail starts up; that powers the inverters and audio output. Seems a bit of an odd way to do it.
              • VaNS
                • Oct 2010
                • 9
                So testing the voltages out of the connector leading to the mainboard.
                -5VSB was a steady 5.23V
                -STB was a steady 5.06V
                -Applied pressure to the mainboard near the input connector while attempting to turn it on (no dice).
                I figured the STB would show some fluctuation if I attempted to turn on the TV; am I to assume this is correct?
                I'm starting to think both the remote, and my key controller board are both broken but that's just crazy talk maybe. The remote is definitely sending out an IR signal (I have an IR receiver for my computer that lights up for any IR device pointed at it). As for the key controller board has no actual buttons on it and is pressure sensitive of some sort (200-700-KF371CH) so I can't physically tell if I'm actually hitting the button.
                Because I have installed a second control box and same issue occurs. Again leaves me baffled.
                  Do you have, or can you acquire a 1kohm resistor?
                  • VaNS
                    • Oct 2010
                    • 9
                    yup, got one here.. what should I do?
                    • VaNS
                      • Oct 2010
                      • 9
                      k so I was really unsure what to do with the 1kohm resistor so I went ahead and googled some testing via 1k ohm resisted and found this set up to test the IR Receiver via LED and 1K ohm resistor and went ahead and did it using well... a breadboard, LED and 4 AA batteries.
                      so... nothing wrong with the receiver that's for sure, but there is seriously something a bit squirrely about how this TV starts up. I'm definitely missing something.
                      I'm honestly willing to try about anything. In terms of equipment or components.. I'm trying to fix this TV for my parents and they run their own little electronics assembly company so there's tons of common components laying around.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Since STB does not change, there is a problem with the main board. At this point I usually suggest checking any fuses and LDO regulators on the main board.
                        PlainBill
                        • VaNS
                          • Oct 2010
                          • 9
                          I actually went ahead and did a reading on the connector afterwards and you're right.
                          24VAMP read 23.7V
                          12V read 10.9V
                          this is still in standby I guess :S
                          PlainBill
                          ok, will look into that.
                          • cajoeg
                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                            by cajoeg
                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                            02-10-2025, 04:01 PM
                            Lithonia Lighting versus Light of America Compact Fluorescent product quality
                            by sam_sam_sam
                            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                            I also have back when Light of America had these light bulbs available for yard lights
                            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                            While the Lithonia lighting fixture has all most certain bulb failure
                            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                            I have only had this light fixture for not more than a year if it...
                            07-02-2023, 03:45 PM
                            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 03:40 AM
                            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 09:10 PM
                            09-06-2024, 08:40 PM
