Hitachi L22H01UB Logo then Blank screen.
  • manicphantom
    • Mar 2011
    I bought Hitachi L22H01UB a while back. Its gone faulty. when you power it up, the "Hitachi" logo will display briefly and the disappear. The screen is then goes blank, however you can see the back light is still on. Remote has no effect. The touch panel responds to touch, but nothing on the screen.
    I did a search on internet and it a apparently a really common problem, however haven't found a solution. This fault also affects the L19H01UB. there seems to be a lot of refurbs on the market, which suggests something dodgy with this model.
    Any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Hitachi L22H01UB Logo then Blank screen.
    Any ideas?
    A failed voltage regulator, a software (firmware) problem, or omitting the heat sink from a chip that needs one are all possibilities.
    PlainBill
    • manicphantom
      • Mar 2011
      I've measured the 3.3V reg for the NXP driver chip and thats fine. measured the voltage from the power supply 12V and 5V seems to be all in tolerance.
      I'm assuming that the Hitachi logo, is generated by the NXP chip at start up. it almost suggests that the NXP is running, however it might be stuck in a loop. But I'm only guessing.
      I know there is a problem with this unit, because when I searched for it in google all I got was refurbished units for sale. also quite a few people have the same symptoms but no answers.
      • kotel studios
        Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
        by kotel studios
        Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
        State I got it in:
        Squealing from the PSU
        After logo I get a blank screen
        After 10 seconds of having a blank display w/ backlight the TV dies
        Give it 7-10ish seconds again and it starts to bootloop.
        What I did so far:
        Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
        Checked all voltage rails:
        5VSB - 4.8V
        AMP+13V - 14.4V
        13V - 12.98V (in manual 12V)...
        09-21-2025, 02:00 AM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
      • abajor
        A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
        by abajor
        Having this very weird issue.
        The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
        I swapped with a working screen from an A2141 waiting for parts.
        The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
        The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
        04-27-2024, 01:37 PM
      • dicky96
        HP Elitebook Screen blank - backlights but no image
        by dicky96
        Hi guys
        I'm trying to fix this laptop screen
        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
        OK so I have the original screen which works but has lines across the bottom quarter of the screen
        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
        04-28-2021, 07:30 AM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
