Stone caps in Twinhan StarBox
  • japlytic
    • Oct 2005
    • 2086
    A few days ago, I found two Stone brand capacitors (470uF 35V) in a Twinhan StarBox VP-7020/7021/7021A. These are used for filtering the 13V/18V LNB supply from a DC-DC converter powered by a 9V 2A plugpack.
    Most satellite receivers have an LNB current rating of up to around 350mA, and this value would not be reached in most cases; so therefore, the capacitors would be unlikely to be of any problem .
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Stone caps in Twinhan StarBox
    But most Satellit recivers are realy hot inside due to bad desing od linear DC regulation. And this will destroy cheap caps realy fast. i think blown caps or simply dried out are the most common problem on sat recivers.
    • japlytic
      • Oct 2005
      • 2086
      The DC-DC converter is a high frequency switching type.
      I found the Stone capacitors were GR series, from the 85C rating and the colour scheme on the manufacturer's website.
      - Stone GR Series
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
