17pw26-4 psu
  • promo7uk
    • Aug 2014
    • 31
    • uk
    Re: 17pw26-4 psu
    Also heres diagram u were looking for,
    • eri
      • Sep 2014
      • albania
      Re: 17pw26-4 psu
      that diode ends with a 402 in my pw26-4 v1.0 and i am not sure if it is the right one
      • eri
        • Sep 2014
        • albania
        Re: 17pw26-4 psu
        well my prob is a have a FInlux tv 32FLD850h model with this psu and the symptoms are blue light , when i click tu turn ON in the tv buttons it makes the clicking sound but no turn on signs if any one can help would be great
        sry for my bad english...
        thanks in advance
        • promo7uk
          • Aug 2014
          • 31
          • uk
          Re: 17pw26-4 psu
          yes mate 402 diode is lower amps and voltage than the 404 ,, these tvs should have been fitted with higher rating diode from the start but was not.. and the amps the psu kicks out to 24v 12v is higher than the 402 diode can take when gets hot takes alot of shit to be fair, so better using a 404...higher voltage higher amps rating, than 402..also if diode open circuit check r1036 surface mount should be 0 ohms. if not its taken that out as well.
          • robinbrighouse@hotmail.co
            • Sep 2015
            Re: 17pw26-4 psu
            There's too many lines, squiggles and heiroglyphics for me! looks pretty though!
            • BenTennyson
              The crazy one
              • Aug 2016
              • 21
              Re: 17pw26-4 psu
              Another Vestel fault here! These things seem to be the spawn of the devil.
              Its a 17pw26-4 rev1 from a Telefunken T37P884 FHD 100 DVB-T.
              (Schematic PDF for this particular PSU is here -> )
              The TV set started out with having an extreme corrupt picture: Moving, distorted multicolored garbage, arranged in horizontal lines. The upper 1/8th of the picture was okay, the rest corrupt. After a day of probing and guessing, the TV set resigned to only go orange light for 15 seconds, then go to standby again.
              According to some training manual on Scribd, the PSU should be in full-on mode when the signal line from the CPU (PL816, pin 6) is 0V so I just took it out of the case and tested without the mainboard (bridged upper and lower screw holes since the lower left area seems to be grounded trough the chassis only).
              C819 Voltage is semi-stable, fluctuating between 398~399v
              3,3v and 5,5v standby and 3,3/5,5v RUN voltages are rock solid, as well as the 24v line. No fluctuations here. BUT:
              After Q827, +12V_BO and +12V both only measure 10v, sometimes going up to 12 but not for long.
              I can't get a proper reading on pin 15 of TR810, since I only have a trashy five bucks digital multimeter, which is measunring 24,5V AC on that pin (+12SV).
              According to these measurements, I presume that Q827 is failing. Agree?
              Is it advisable to replace it with same type (STPS_3P_10L60CFP) or is there a better alternative?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Re: 17pw26-4 psu
                I would say so or the controller for it have you checked all the small caps as well if one of them fails it can throw the controller off ?
                • BenTennyson
                  The crazy one
                  • Aug 2016
                  • 21
                  Re: 17pw26-4 psu
                  I replaced C851, C863 (12v rail) and C850 in the 24v rail with new caps instantly even before taking the voltages because they were bulged, although I replaced the caps in the 12v rail with 50v rated ones instead of 16v.
                  Should I check all the caps on the primary side of TR810 too?
                  Btw when you say 'controller', are you referring to IC830? Wouldn't the 24v rail be affected too if IC830 was glitchy?
                  Sorry if these questions sound stupid, I'm still learning. And this is my first try at a PSU.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Re: 17pw26-4 psu
                    Yes check the smaller side primary caps. Also I believe that the 24v rail is ran on a separate winding and controller for these. Let me check.
                    • BenTennyson
                      The crazy one
                      • Aug 2016
                      • 21
                      Re: 17pw26-4 psu
                      Looks like this PSU has already been fiddled with before. I just noticed that Q827 in this PSU is an STPS20S100CFP
                      instead of a STPS_3P_10L60CFP like listed in the schematics. Hard to imagine that this one just failed like that. I will check the rest of the caps tomorrow.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Re: 17pw26-4 psu
                        It might not have been Vestel have well over 100 different schematics and designs for this board, they just throw whatever parts they have on the Pcb to get it to work.
                        • BenTennyson
                          The crazy one
                          • Aug 2016
                          • 21
                          Re: 17pw26-4 psu
                          Ok now while I was probing the caps, the PSU is back to never switch on the running power rails at all. 5V STBY voltage is fluctuating heavily.
                          C892 never reaches 12v, which it SHOULD, according to this datasheet for IC806
                          The voltage on C892 fluctuates between 6-11volts
                          • BenTennyson
                            The crazy one
                            • Aug 2016
                            • 21
                            Re: 17pw26-4 psu
                            PSU working with stable rails, TVset turns on but still has horizontal lines/picture corruption. Looks like the mainboard is borked.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Re: 17pw26-4 psu
                              Let me guess LG panel ? Also what did you do to fix Psu ?
                              • BenTennyson
                                The crazy one
                                • Aug 2016
                                • 21
                                Re: 17pw26-4 psu
                                Quick solution: Bought a good one on ebay, because I've not enough time left to mingle around with this tv. I'll keep the faulty PSU and report back here if I can bring it to life again. Oh and yeah, its an LG panel. I witnessed something: The picture corruption goes away if I let it sit turned on for a few minutes. It continued to run flawlessly for a few hours until I put it into standby again. This morning I verified this, it showed the exact same behavior. Horizontal corruptions which vanished after a few minutes. Also measured the power rails of the PSU under load directly on the mainboard, everything stable. Voltages on the smaller two caps on the mobo fluctuate between 6-7volts. I dont know if that is ok, cant find schematics for that board. The caps are new, I replaced them before fiddling with the faulty PSU.
                                ~~uploaded a video so you can actually see what I'm talking about:
                                https://youtu.be/Mj9qVfbir1c
                                Note how the upper few rows of pixels are always good. The board seems to desynch from the HDMI-signal for a second inbetween.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Re: 17pw26-4 psu
                                  Ive had that on them 37LC panels so has user Dick Barton I was able to sort mine by replacing the ribbon cables going from the Tcon to the panel but he never sorted his I also had another which I couldn't sort. I cant help much sorry lets see what others think.
                                  • BenTennyson
                                    The crazy one
                                    • Aug 2016
                                    • 21
                                    Re: 17pw26-4 psu
                                    I think I'll open a new thread about this issue since this isnt about the PSU anymore. Thread-hijacking is a bad habit of mine >_>
                                      Acer TravelMate B118-M-C878 Notebook B Specification for Upgrade or Repair
                                      This specification for the Acer TravelMate B118-M-C878 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the B118-M-C878 boardview and B118-M-C878 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 08:32 AM
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • fharris1977
                                      Vizio D50u-D1 Dead Set No Standby
                                      by fharris1977
                                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                      12-28-2023, 10:25 AM
                                    • Crystaleyes
                                      Samsung BN44-00259A standby question
                                      by Crystaleyes
                                      Hi all.
                                      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                      08-11-2023, 05:15 AM
                                    • reessi
                                      JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                      by reessi
                                      I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                      You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                      Years ago it had some bulging caps...
                                      04-26-2021, 11:42 AM
