LG 42PC1RR-ZL y sus problem
  • luiznunes
    • Sep 2011
    • 33
    Re: LG 42PC1RR-ZL y sus problem
    anyone knows what is the IC13 KA5H080R on the circuit ?
    http://images3.hiboox.com/images/390...fa988718f8.bmp
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Someone was hungry and the 3 was the only thing he could find to eat. Here you go. It's a power supply controller with built in power mosfet.
      A working TV? How boring!
      • luiznunes
        • Sep 2011
        • 33
        since I don't have the exact schematics of this board ( the PS101 ), how can I discover what is wrong with it?
        • PlainBill
          • Feb 2009
          • 7034
          You start by taking pictures of the power supply - one of the top and one of the bottom - and posting them HERE using 'Manage Attachments'. I've had enough problems with '.jpgs' posted offsite that wouldn't open or contained something extra. Don't post them inline.
          PlainBill
          • luiznunes
            • Sep 2011
            • 33
            you mean the power supply board, or the PS101 of the Ysus board pictures?
            • PlainBill
              • Feb 2009
              • 7034
              Sorry, it was early and I wasn't paying attention. Yes, pictures of the top and bottom side of the PS101 would be helpful. It may be necessary to use wires to extend PS101 above the board so you can make measurements.
              Actually, let me make a suggestion. With PS101 still in place take pictures of the top and bottom showing as much as possible. I have a similar board here; if they match it will make things much easier. If they don't, well, it's little time lost.
              Or you could shotgun it by replacing the electrolytic caps.
              PlainBill
              • luiznunes
                • Sep 2011
                • 33
                #27
                hey, you don't have to appologize!
                I am the one who's need help!
                here it is the pictures. if you can see what you want, please tell me and I take more.
                • PlainBill
                  • Feb 2009
                  • 7034
                  It's built on the same board, but there are a few dash number (version) differences, almost certainly due to a different output voltage. Borrowing on other reports, I'd replace C25 - it's the smallest electrolytic cap - 100 uF, 35 volts on mine. If that is leaky it could affect the output voltage.
                  PlainBill
                  • luiznunes
                    • Sep 2011
                    • 33
                    #29
                    to replace it, I need to un-solder the PS101 from the Ysus, right? because I don't have much access to put an iron there..
                    • luiznunes
                      • Sep 2011
                      • 33
                      #30
                      don't you think that, because of the very slow drop of voltage until it reaches the correct 200V is due to a faulty resistor?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Yes, you will have to remove PS101 from the main board.
                        While it is possible, it's unlikely. Others have reported problems with these units and found it was due to a bad cap.
                        And it turns out my memory was faulty. Here's the post. Perhaps there are enough clues to help you.
                        PlainBill
                        • luiznunes
                          • Sep 2011
                          • 33
                          #32
                          PlainBill
                          already replaced. problem remains the same...
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Off to do some yard work and cogitate on the problem. Bump the thread if I don't update by Monday evening.
                            PlainBill
                            • luiznunes
                              • Sep 2011
                              • 33
                              #34
                              ok, thanks.
                              • luiznunes
                                • Sep 2011
                                • 33
                                #35
                                I measure the output of the transformer and is a stable 210V
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  OK, now you have me thoroughly confused. Is the output of PS101 a stable 200 (or 210) volts?
                                  PlainBill
                                  • luiznunes
                                    • Sep 2011
                                    • 33
                                    #37
                                    PlainBill
                                    more or less stable. Why?
                                    • luiznunes
                                      • Sep 2011
                                      • 33
                                      #38
                                      PlainBill
                                      It shouldn't be stable or shouldn't be around 200?
                                      I can check again.
                                      Isn't the PS101 the same as the PS102? Same component and values except the transformer?
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        I can check again.
                                        Let's see if we are on the same page here. In an early post you indicated Vy was too high (250V) and the picture was bad when the TV was turned on. After a few minutes Vy would drop to the proper value and the picture became good. Or am I totally confused?
                                        After changing C25 is Vy stable and is the picture good when the TV first comes up??
                                        PlainBill
                                        • luiznunes
                                          • Sep 2011
                                          • 33
                                          #40
                                          PlainBill
                                          Ok, my bad. I must measured the PS102 that time. sorry.
                                          Here I enclose a PDF file showing the evolution of Vy and the output of the transfomer. If you want I can send the excel file with the data.
                                          I was asking about the PS101 and PS102 having the same schematics, so I may compare some values between them.
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                          • vabea
                                            Asus X550LD Image problem
                                            by vabea
                                            Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
                                            Thanks...
                                            04-07-2025, 08:33 AM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
