LG 50PC1DRA Plasma Tv
  • redrock
    • Sep 2011
    have a LG 50in PlasmaTv (50PC1DRA) and getting a message when I power it on 'HDD Problem Detected'...It pops and cuts offseveral times before I can get it to stay on. . I have tried unplugging when it is on.... foe 2 to 3 hours and the tv come on fine but the next time I power on it's right back like it was. Once the tv does stay on, there is a ticking sound on the left hand side for about 10 seconds& then its fine..Has this happened to anybody ?? and if yes is there a solution!!
    Re: LG 50PC1DRA Plasma Tv
    HDD problem detected? My first guess is that it has a hard disk and that has a problem..... but why would a plasma TV have a built in HDD? Does it record content? Is it an internet TV?
    • PlainBill
      • Feb 2009
      • 7034
      From the February 9, 2007 PCMagazine review of the 50PC1DRA plasma TV
      The LG 50PC1DRA is a 50-inch HD plasma that offers the convenience of a built-in DVR, but it spoils the fun with generally unimpressive ...
      The service manual is available at Elektrotanya. It probably contains information on replacing the hard drive.
      PlainBill
      • redrock
        • Sep 2011
        PlainBill
        thx Bill!!
        • redrock
          • Sep 2011
          thx Tom !! it has built-in DVR,
            Well, the first task would be to take the back cover off the set, and take good pictures of the inside, then post them here, so we all know what we're dealing with. Up to 2000x2000 pictures are allowed on this forum.
            You'll probably need a new HDD for it. If it's 160GB and SATA like what I have read, that will cost around £20. The same drives are used in many modern desktop computers. It could also be small form factor (laptop size), in which case that would be £35-40.
            The ticking sound is very much characteristic of a failed disk drive. It startles me that it will not let the set power on but disable the recording feature until it's been serviced; nope, it just stops you using it entirely.
            • PlainBill
              • Feb 2009
              • 7034
              I hadn't thought about that, but you are correct - it seems to be a really poor design decision.
              PlainBill
              • ArMaaN376
                Samsung PS51E550 Plasma TV
                by ArMaaN376
                I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                Opened TV cover & observed foll
                a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                How to confirm Y -Buffer board...
                06-19-2024, 04:05 AM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
              • chazh
                LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                by chazh
                This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                09-01-2025, 08:56 PM
              • Malcolma172
                Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
                by Malcolma172
                I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
                After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
                After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power...
                07-23-2025, 01:20 PM
