anyone experienced with samsung plasma tvs ( picture fault )
  • joey
    • Jun 2010
    • 14
    hi guys been working on 3 ps50c97hd samsung tvs.
    all tvs had no picture due to blown top buffer and y-sus. i repaired all 3 ysus on all 3 tvs and tv now powers up by just trying lower buffers which were ok as only top had shorted.
    however on all 3 tvs im getting a strange green dot type pattern?
    this happens on all 3 tvs. on first thoughts im not convinced its still the ysus as all 3 are acting the same and all 3 tvs are using a different y-sus & bottom buffer. and were repaired by replacing the blown mosfets.
    anyone have any ideas as its strange this is happening to all 3 tvs which the ysus was repaired.
    i have checked vs.va. scan all all voltages correct.
    http://www.youtube.com/watch?v=AKus6DnrorA
    heres a video below showing problem. has anyone come cross this problem.
    thanks
  • Toasty
    • Jul 2007
    • 4171
    Re: anyone experienced with samsung plasma tvs ( picture fault )
    Video is post-repair?
    What's it look like with both buffers connected?
    veritas odium parit
    • PowerAmpFreak
      • 982
      • Sweden
      Not much of help, but I had exactly the same issue on a PS50Q96HD a couple of days ago, top chip blown on upper buffer, mosfet bank shorted on Y-SUS.
      Lower buffer didn't show a sign of damage, but it's not sure.
      In your case, upper buffer short may have damaged the lower buffer. I hate such failures, may it be the same case as when Samsung used the bad silicone which after short time made the buffer blow due to poor isolation. Oh god.
      • rayrod81
        • Oct 2010
        • 205
        Yeah it looks like the bottom buffer is bad as well. I have seen this fault even when the board is not shorted.
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
