Dead LG 50PS80ED
  • gunnahafta
    • Aug 2011
    • 6
    Dead LG 50PS80ED
    Hi all, i have a LG 50inch Full HD Plasma model 50PS80ED. For 2 years it worked great until this morning when i turned it on. I power it on and you hear the usual click, the white light across the bottom comes on but the 3 or 4 seconds later it goes into what appears to be standby mode. I try to wake it up from standby and the same thing happens, the white light coems on but them back to standby a few seconds later. No picture or sound.
    Ive read a few threads and there has been a number of suggestions about checking cap's aloing with many pictures for reference. To my best observations they all look ok to me. Cant see any obvious blackening etc to indicate a burnt out component. Can any one suggest thigns to do to test different things like pulling a particular cable to see if its power supploy or something else etc. Any help would be great.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dead LG 50PS80ED
    Since you didn't help us by supplying pictures, I'll return the favor.
    1. Check the output voltages from the power supply, particularly the voltages listed on the white label on the back of the plasma panel itself.
    2. Disconnect the heavy cable from the power supply to the Z-sustain and see if the TV will stay on. Then reconnect it. (You may not see a picture.)
    3. Disconnect the heavy cable from the power supply to the y-sustain and see if the TV will stay on. (You will not see a picture.) Do not reconnect it
    4. Once again, disconnect the power cable from the Z-sustain and see if the TV will stay on.
    Report your results.
    PlainBill
    • gunnahafta
      • Aug 2011
      • 6
      Sorry about the lakc of pics i didnt have means to attach any at that time. results of your suggested steps are:
      Step 1. Couldnty test dont have a meter
      Step 2. Powered on and stayed on. Also had the usual LG logo complaining about no input
      Step 3. Powered on and stayed on. No picture
      Step 4. Powered on and stayed on. No picture
      As an extra step i plugged them both back in and turned it on. same thing happened, it powers on for a few seconds thengoes straight into standby. also when it did power on i hit a button or two on the remote and the white light on the TV flahsed like it usually does indicating its recieving the IR signal frmo the remote.
      • gunnahafta
        • Aug 2011
        • 6
        Pics, i dont see any Bad Caps
        • PlainBill
          • Feb 2009
          • 7034
          1. Kind of hard to troubleshoot without a meter.
          Steps 2-4 Inconclusive, indicates the power supply is PROBABLY bad, but I'd hate to buy a replacement on such poor evidence.
          PlainBill
          • PowerAmpFreak
            • 982
            • Sweden
            No hard feelings, but if you don't even have a meter, than you probably do not have the necesary knowledge about power electronics testing and fault finding. A plasma TV runs of lethal voltage levels, especially in primary part of the powersupply. Please take this as a warning and nothing else. This forum is full of people who put much time to help others with TV repair, but without a meter and at least a basic knowledge of electronics repair, we will have no chance of helping you, together with the risk of having yourself injured.
            • mazdaverx7
              • Aug 2011
              • 8
              if you do go out and purchase a multimeter, please do not buy a cheap unit. i have been using Fluke brand meters for years and i recommend them. i have used cheaper variants from craftsman but never on home electronics/AC.
              • PlainBill
                • Feb 2009
                • 7034
                I strongly disagree with this statement. Fluke make some very good, rugged meters for the professional. They are a good investment for anyone who requires one for his job. While I do NOT recommend the cheap meters found on eBay for under $5.00, the fact is a meter suitable for the casual user can be had for a fraction of the price of a Fluke. I'm using one that cost under $25, and it has proved to be reliable and accurate.
                PlainBill
                • gunnahafta
                  • Aug 2011
                  • 6
                  I just didnt have access to one at the time. It's not actually at my place and had to make a flying visit. Im by no means a professional, more of an amatuer. I've put together kits, made repairs, replaced caps etc before so i feel im competent enough but would happily welcome advise from professionals especially if you have some good advise to give when taking leter readings in high voltage areas like this. So before i get the meter and check it i welcome any advise you have to help.
                  P.S. Did anyone see any bad caps or anything else in the pics? I didnt see anything would like to know if someone could confirm that.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    I'd say you are more of a hobbyist than an amateur, but that's my opinion.
                    When measuring the voltages always keep one hand in your pocket.
                    No obvious signs of bad caps.
                    PlainBill
                    • gunnahafta
                      • Aug 2011
                      • 6
                      Cheers Buill i suppose you could be right there. I've put together plenty of PC's ans replaced bad parts etc when they are odvisouly bad.
                      I've heard the hand in picket tip, stops the current from using you to ground to the earth right.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Yeah. Even standing on a concrete floor in your bare feet, it's unlikely enough current would flow to kill you if you touched the output of the PFC circuit. Holding onto the frame of the TV with one hand while probing the Va suppy - not so safe. Trying to see what would happen if you touched Va and -Vy at the same time - really, really foolish.
                        PlainBill
                        • gunnahafta
                          • Aug 2011
                          • 6
                          PlainBill
                          I hear you. Im heading with the meter to take some readings in a day or two. You said to take readings, when refering ot the picture i attached (IMG_0358.JPG) are you refering to check the voltages marked on the board where the two heavy cables connect on the botton left and bottom right of the pic?
                          Hmm lokos like my level of expereinces is catching up with me
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Yes, those are the cables that carry power to the sustain boards.
                            PlainBill
                            • tvguy12012012120
                              by tvguy12012012120
                              02-07-2025, 05:13 PM
                            • piposarcade
                              Samsung UN50KU6300 dead no standby led
                              by piposarcade
                              01-04-2024, 01:33 PM
                              Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                              05-22-2024, 02:07 PM
                            • fharris1977
                              Vizio D50u-D1 Dead Set No Standby
                              by fharris1977
                              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                              12-28-2023, 10:25 AM
                            • jacobtc
                              LG C1 65'' dead standby
                              by jacobtc
                              I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                              If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                              If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                              I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                              01-29-2025, 04:27 AM
                            • piposarcade
                              by piposarcade
                              Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                              01-04-2024, 12:03 PM
