Philips 42" 715T2432-2 issues
    Re: Philips 42" 715T2432-2 issues
    Thanks for the info Ron. I have seen those kits. I already did the main 3. Looks like i will order the rest of the caps and the 2 diodes this weekend and give it a try.
    Stupid People are like Slinky's. Not really good for anything but they bring a smile to your face when you push them down a flight of stairs.
      Hi Mavrick2k,
      did you resolve this ? I'm at the stage of replacing the Zeners ZD904 and ZD902, I'm also replacing the rectifier STPS40H100CW, Dual Schottky Diode, 40A 100V Common Cathode, Dual, 3-Pin, TO-247 at D922, I've ordered most of the caps as well.....getting fed up with this PSU....seems like its a common fault, just wondered if there was a iron clad fix for it....other than trial and error
        I had not reordered parts. I got busy and had not had time and then i did some more research. Seems like people do get it running again by replacing majority of caps and zd902&904. One post had stated the Q902 - Shorted. Got a new meter that did capacitance so tried testing a few caps. pulled five off the board and all five tested bad. Then tested with a friends meter with the same. Thought about getting a esr meter but dont want to spend the money for as little as i would use it. I tested 922 and got a short. So I am putting in the order now for 11 caps 2 diodes and that rectifier.
          I've resolved the issue with the power supply I had, same issue chirping on startup/load I've replaced the following parts and now have a working PSU
          C953,C952,C951, C955, and the big 220uf 450V cap
          ZD904, ZD902
          D922
          (5 caps 2 Zdiodes 1 rectifier beats your 11 caps 2 Zdiodes and rectifier ....<grin>)
          Just thought I'd pass on my success on this repair (your mileage may vary)
            I've got to say I'm appalled at Phillips the company they are about as much use as a chocolate fireguard when it comes to helping the end user.....that's the problem these days with this throw away society we live in .....its' a shame
              I orderd 11 caps because i figured to go ahead and get rid of all the crapxcon while i was at it. I did not order the big one though and I did not test it. Was yours bad or did you replace it just because. I prolly should have ordered it as well.
                Well I replaced everything. Tv Fired up fine went through menus. I got excited went out and got a wall mount for the bedroom. Mounted the sucker hooked everything up and powered on. Damn thing started chirping again
                  The big cap was bad on mine
                    check those zeners haven't blown again @ ZD904, ZD902
                      the problem i have traced down is the zd906......spray it with a can of air upside down and it should change the chirping sound. and thats the problem. fixed my tv
                        anyone know where I can order the zd906? got a part number for it? I am going to look on digikey Im not sure where else to look
