Samsuung SyncMaster 170MP TV/Monitor
  • PlainBill
    • Feb 2009
    • 7034
    This is a 'social' freebie. One of my friends had given it to me. His description of the problem was "You can hear the heartbeat, but there are no signs of life". When I plug it in, I can hear what he was talking about - a slow (every 2-3 seconds) pulse from the speakers, but no response from the buttons on the front.
    This uses a power brick (12V, 4.5A), which lit both filaments of an 1157 automotive lamp brightly. Scoping the output showed a clean voltage. I then downloaded the service manual and disassembled the monitor. The design was simple - input DC went to 5V and 3.3V bucking regulators and to the inverter. Disconnecting the inverter made no difference, disconnecting the tuner portion of the TV also made no difference. I did notice the same 2-3 second pulse on the 3.3V supply. A long look at the schematic showed the output of the 3.3 volt supply went to dozens of ICs. I was preparing myself for a difficult troubleshooting project when I noticed the same 2-3 second pulse appeared on the 2.5V supply, which was derived from the 5V supply. And that led me back to finding the same 2-3 second pulse on the 12 volt supply.
    Since I didn't have an equivalent supply handy, things sat there for about a month when I had the opportunity to buy a variable bench supply (0-30V, 0-5A). Hooking that up to the power connector resulted in elimination of the pulse, but the backlights would not come on completely. Checking the output of the power brick, I discovered that while it was labeled as providing 12V at 4.5A, it actually put out 14V. Boosting the output of the bench supply to 14 volts gave me full backlights. With that information I hooked up a Kensington 'Universal' power adapter and discovered I had a working TV/monitor.
    Next I turned my attention to the 'power brick'. A quick investigation showed the 1157 lamp draws 2.7A if both filaments are on, well below the specs of the power supply. Opening the power brick was easy, removing the supply from it's case was anything but. Eventually I got it out and stared checking. Of course, it was well coated with adhesive, the same one that held it in the case. Checking the ESR of the caps (SamYoung) showed they were roughly at spec. Removing them from the board confirmed this. After some thought, I ordered replacements for the three output caps and the mains filter cap. The startup cap was buried under more adhesive, besides I had those on hand. Installing the caps and testing it gave me the same pulsing sound. Prying the adhesive off, I was able to extract a 47uF, 50V cap of uncertain ancestry. Replacing it, I hooked the power supply up, and was rewarded with the same pulse - but only a single beat!!! Turning to the TV / monitor, I discovered it was working.
    Conclusions - Check power supplies at full load. And just because a power supply produces an output at no load, don't assume the startup cap is good.
    PlainBill
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsuung SyncMaster 170MP TV/Monitor
    Good read. Well written and easy to follow. I noticed on a small power supply (digital picture frame), the SMPS was showing more voltage unloaded that what it's rating was. I haven't gone into too many to notice a trend of what may be the standard but I have seen this before. Maybe there's like a 20% over voltage rule of thumb for SMPS's or something. I know I wouldn't have had even a shot at figuring that one out. I dont have a supply with that much ass behind it. - That set would have been laughing at my 32VDC @ 1A max supply.
    • PlainBill
      • Feb 2009
      • 7034
      Over the years I've accumulated a good deal of test equipment, including some reasonably powerful 5V and +- 15V supplies. The only variable one I had was a 0-25V, 0-250ma one, which just roll over and says 'Uh-uh' when presented with anything major. The new bench supply wasn't cheap (and shipping almost brought tears to my eyes), but I'd just sold a couple of monitors and felt this was a good time to indulge myself in a substantial bench power supply.
      PlainBill
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
      • penangit
        Hp v193 monitor power supply board
        by penangit
        Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
        I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
        I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
        Steps taken so far:
        Checked all...
        02-21-2023, 04:00 AM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
        07-01-2024, 06:34 AM
