Technika 20" TV LC-TM2018
  • llphat
    • 20
    I have recently found a Technika 20" LCD TV which appear to be non-working. After opening up I found that the three bigger capacitors at the output side on the power board is bulged. After changing the caps the 12V output is still not present, what else could I check?
    Please see attached schematic for the power board LM-TM2018. I have replaced the three bulged caps C914, C915 and C916. What damage could these bulged caps have caused to the rest of the circuit?
    Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Technika 20" TV LC-TM2018
    I don't get a chance to say this often enough. Thank you for including the schematic.
    I'd check the voltage across C904; it should be approximately 1.4 x your line voltage (if your line voltage is 120 VAC, it should read 165 volts). If it reads 0 volts, check F901.
    Also, V909 is a suspect. If it's bad the power supply won't start.
    PlainBill
    • llphat
      • 20
      Voltage across C904 reads about 330V which is what I would expect for a 240V input (U.K.). Fuse F901 is intact.
      With regard to V909, I think perhaps you mean C909. I will check with a suitable replacement. I will probably also check C910 while I'm at it.
      Thank you.
      • PlainBill
        • Feb 2009
        • 7034
        Thank you.
        Yes, you are correct. Fat finger mistake.
        PlainBill
        • billiearmendaris
          • Mar 2013
          • México
          Thank you.
          Hello llphat, how are you? Hey, we'd like to know what was the solution to your problem please. We have the same one. Thanks in advance.
            How? Technika aren't sold out of Europe.
            • billiearmendaris
              • Mar 2013
              • México
              Indeed, but we have a Daytek TV LCD, however the power supply LC-TM2018 is the same.
              • zvikar
                • Sep 2015
                • israel
                hello, i replaced the three big capacitors and D903 (was short) and the power supply start to work
                • triplefour
                  JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                  by triplefour
                  got this tv from a friend who got a new one and didnt want to bother repairing this one.
                  he said it sometimes would just flash color patterns.
                  and sometimes it would just work
                  i figured it had some intermittent mainboard issue.
                  i stored it at home for a while before looking at it
                  when i plugged it in for the first time, i heard some popping noises
                  and then a big cloud of white smoke came out of the back of the tv!
                  i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                  i unplugged it and took the back off and discovered...
                  12-18-2022, 12:38 AM
                • unimatrix93
                  Technika T32HD-278-17 (VESTEL)
                  by unimatrix93
                  Hello everyone!
                  My crappy Technika TV has a flashing red light symptom. Black screen, Voltages looks good.
                  Does anyone have the EEPROM bin file for this model?
                  Technika T32HD
                  MB: Vestel 17MB140
                  Panel: VES315WNDA
                  Thank you!
                  06-16-2022, 04:11 AM
                • rustinjust
                  technika tv, 32 inch,capacitor replacement question, useful advice needed
                  by rustinjust
                  I have a technika tv, 32 inch, around 10 years or so in age and last night when watching tv i heard a hissing sound and the next thing i saw smoke coming out the back of the tv, i instantly unplugged the tv. I took the back off tv to expose power board, then plugged in tv and saw smoke coming out of a capacitor, i will try and attach a photo below, see below for attachments of board and cap, and keep reading, maybe you can advise ?
                  The cap says on it: 105kj450mff4. This doesn't mean a lot to me as i'm an amateur when it comes to electronics, though i've undertaken some repairs such...
                  06-07-2022, 08:29 AM
                • l3emarsh
                  technika 40F21B-FHD
                  by l3emarsh
                  black screen and no sound but led turns blue when switched on and flashes when remolt button pressed?
                  Any ideas?...
                  01-02-2024, 02:10 PM
                • l3emarsh
                  technika 40F21B-FHD
                  by l3emarsh
                  i asume this tv is vestel firmware and i have vestel firmware files, all i ask is how to install them on to this TV????
                  Any instructions would be greatfull. thank you...
                  01-02-2024, 01:51 PM
