Pioneer PDP-502MX Power problem
  • moldymac
    • Jan 2011
    I have a 50" Pioneer plasma set that will not power up for me. When plugged in, you get a solid green power light, you hear a click, then the light starts blinking and goes solid again. Nothing comes up on the screen and the fans won't spin. I opened it up to find after the light stops blinking a red LED on the power supply board comes on labeled "MAIN". The other LEDS are off. I called Pioneer and unfortunately they no longer offer the free power supply replacements for this tv. The agent I spoke to said that light does mean a power supply failure. Has anyone had any luck fixing the power supply on this tv? None of the caps appear blown on it, I'm not too sure where to go from here. Thanks!
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Pioneer PDP-502MX Power problem
    Post a couple of clear photos of this power supply board - front and back. I'm sure there's someone here that can help you. If it's a set that is known for that failure, I'm almost certain there's got to be someone that will chime in to help you. Also with the photo's, post any numbers on the board. That could be helpful also because sometimes these power boards are used in multiple models.
    When posting pictures, use "Manage Attatchments" on the posting page.
    Good luck and welcome.
    • moldymac
      • Jan 2011
      I'll get some pics of the board. Hopefully someone knows something about this board, must be fairly common if pioneer started a replacement program.
      • moldymac
        • Jan 2011
        I got the board out, heres some pics of it. Every time I tried to upload it as an attachment it gave me a security error, so here they are hosted off photo bucket.
        Numbers on the board:
        Main Power Ass'y AWZ6506
        Power Supply ASS'Y 1845-A A2UL06 (stamped)
        On and edge ANP1966-A
        • retiredcaps
          • Apr 2010
          • 9271
          The photos allowed here must be 2000x2000 or less. And I believe the largest photo allowed is 2MB each.
          --- begin sig file ---
          --- end sig file ---
          • PowerAmpFreak
            • 982
            • Sweden
            Are you sure the powersupply is the problem?
            What if you power up the psu alone, without connected Y-SUS and Z-SUS boards. Most of the PDP powersupplies has overload detection/shutdown, which will kick in if connected to faulty display power boards.
            Have you tried to get hold of a service manual?
            • PowerAmpFreak
              • 982
              • Sweden
              Please visit http://www.elektrotanya.com to find a service manual for the set.
              • dziundzis3
                • Oct 2012
                • Klaipėda
                Hi, see an old theme of this TV.
                Have the same model and etc. I have all most powered on the TV but one mistake burned out more parts. So now I have a problem. Realay turns on and then turns off and repeats it all over again. It doesne't matter what is going on on the board. I removed all RCC's and all OTL's it's still doing that. Everything what is working is STB power lines. It wont start other parts of power supply. Any LED showing an error, but it's only becouse of all power supply doesn't start. In schematic there is no many parts of supply so that makes it fix harder. Maybe some ideas about that?
                If you still have that board would be great if you would say some parts of it. That would be:
                Q203 it's near Q201 (first main transistor) - whats written on it. Is it BS or FR?
                D234 it's on RCC (little board near Q201) - it's A or A5 or what?
                I'm so close to starting it. Would be great to get some help...
                  I have fixed this PSU before. The FET for the Vs fails short, which burns out some of the pre-charge resistors. PSU will need FET replaced and pre-charge resistors replaced. (The white ceramic ones near the mains power in.)
                  • dziundzis3
                    • Oct 2012
                    • Klaipėda
                    Already done that. Ceramic resistors are fine, changed one already. FET is schanged. Few days ago power supply was almost working properly.. I mean I didn't pluged the connector of Vsus and etc. it Showed an error with LED, but now it wont start at all.. The second relay RLY131 doesnt work for some reason I don't know..
                      Spray contact cleaner in the Vsus adjust pot, turn it a few times and try again, does it get better?
                      • dziundzis3
                        • Oct 2012
                        • Klaipėda
                        The problem is that everything what is working is STB power no Vsus; ADR +10; +14 etc.. There is just +12 STB and +5 STB
                          I don't know then, I have had the MAIN switch off problem before on this plasma (in fact it's still in the shed, waiting to go to the dump!!) My one however has a white bar on the screen which is plasma panel failure, so it's not economical to fix.
                          • dziundzis3
                            • Oct 2012
                            • Klaipėda
                            So maybe you can answer this?
                            That would be really helpfull. On my board q203 just gon by blowing up so I dont know what was the real one.. I putted an NPN there (BS) so.. That could be a problem of not turning on maybe?
                              Unfortunately, I'm about 400 miles away at university!
                                03-31-2024, 02:12 PM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                                07-01-2024, 06:34 AM
                              • JimBanville
                                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                by JimBanville
                                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                09-13-2023, 07:21 AM
                              • burntonnerings
                                Acer K272HUL blue power light but black screen, power supply is ok
                                by burntonnerings
                                Have had two Acer K272HUL monitors die with the same symptoms:
                                - Blue power light is illuminated while the monitor is plugged in
                                - Black screen (no splash screen, etc.)
                                - Power button doesn't do anything
                                Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                                Power supply voltages are fine.
                                There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                                Anyone have any ideas?...
                                12-09-2023, 10:22 PM
