Re: Toshiba 32HLC56
As far as how the inverter works, there are two possible configurations. One is each secondary winding drives one CCFL. The other end of the CCFLs are grounded. The other (more likely) configuration is both secondaries drive the ends of a single CCFL. The windings are 180° out of phase. The other ends of the secondaries are used to sense current. The white patches near the output connectors cover a pad etched in the board. They are one plate of the capacitors used to sense output voltage. The other plate is a layer inside the board.
The inverter works by generating a constant current. If the voltage across any CCFL, or the current through any CCFL goes too high or too low, the inverter shuts down.
PlainBill
PlainBill
