LG 50PC3D-UD power issue
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG 50PC3D-UD power issue
    Originally posted by nswizdum
    It shows less than 15ohms resistance between each pin, in both directions, which is different from the other similarly labeled components. Theres also a box capacitor next to it that is caved in on the sides.
    Remove the component and verify "out of circuit" that it is shorted. Sometimes a low ohm resistor or some other component will cause false readings while "in circuit".
    The store sells mostly NTE parts, for future reference, are NTE caps generally of good quality?
    You want to stick with these electrolytic brands listed here ...
    https://www.badcaps.net/forum/showthread.php?t=2280
    --- begin sig file ---
    --- end sig file ---
    • nswizdum
      • Jan 2011
      • 18
      Yep, I have already removed it and tested it, same result.
      I'm having a hard time finding a spec sheet though, are there any places I should be checking besides http://english.electronica-pt.com/? I found a few people selling them on ebay, but purchasing electronic parts on ebay is a bit like purchasing prescription drugs from a street corner, no idea whats actually in it.
      • retiredcaps
        • Apr 2010
        • 9271
        If you buy from
        http://cgi.ebay.com/SD20N60-power-MO...134472#vi-desc
        Coppell TV repair is very reputable. They have a blog that gives alot of repair info. I know PlainBill visits their blog. See http://blog.coppelltvrepair.com/
        If you want info, send them an email and I'm sure they will respond back to the auction. Also note the details they give in the auction about checking the lower power components in the drive circuitry.
        I personally would have no hestitation in buying from them.
        • nswizdum
          • Jan 2011
          • 18
          No dice, still the same problem after replacing that mosfet.
          • nswizdum
            • Jan 2011
            • 18
            Well, that was fun. I powered the TV on again to check some more points, and when I started testing points, there was a really loud pop (ceramic fuse blew). 4 of the power mosfets on the first heatsink bit the dust as well. I think it may be time to buy a new power board, 4 mosfets is $40, and I still don't know what the original problem was.
            • nswizdum
              • Jan 2011
              • 18
              #26
              Upon further inspection, it appears that the fuse was blown when electricity arced from one of the mosfet solder points on the bottom of the power board, to the back of the plasma panel. I had it in the proper mounting holes, what would cause that? Some kind of overload?
              • JSK-MX
                • Nov 2011
                #27
                Following this with interest because I have the exact same tv and problem. Replaced the 9 bulging 10v3300uFs on PS, but no luck. On control board D15 on the Temperature Diode stays green, D17 lights immediately after and buzzes, then shut down. Any quick help? And to OP, did you fix the thing? Thank you.
                • nswizdum
                  • Jan 2011
                  • 18
                  #28
                  I did eventually get it fixed (with help from Coppell TV Repair). It was one of the MOSFETs causing my problem. I broke my rule of "no soldering after midnight". A bead of solder dripped off the MOSFET pin and shorted a connection that was hidden under the heatsink. That was what caused the sparks and blew a bunch of the MOSFETs again. Still happily using that TV now.
                  • CAnderson
                    • Nov 2011
                    #29
                    I have a similar problem with the 3 flashes of green. I replaces the caps but still nothing. I however don't have the control board LEDs lighting up at all. What would keep them from working/ getting power?
                    • caspermccormack
                      • Mar 2012
                      • 112
                      • Ireland
                      #30
                      Hello, I too have the same board in my Lg 50PC1d plasma, At first the Ysus was replaced and both buffers were checked out and are in working order. However the problem I now have is the power board won't stay switched on (5 seconds before it switches off). I looked for the voltages from the Va and Vs and found that the Vs briefly hits 56.4and drops before it knocks off and the same for tha Va (17.3). The relays that click for on/off are at the bottom of the board, could these be the problem?
                      Thanks inadvance,
                      Anthony
                      • TechShui
                        • Jun 2011
                        • 148
                        Hello casper,
                        Have you tried unplugging the Z board to see if the TV stays on for longer than 5 seconds?
                        • caspermccormack
                          • Mar 2012
                          • 112
                          • Ireland
                          #32
                          Originally posted by TechShui
                          Hello casper,
                          Not yet, I'll give it a try and post back.
                          Cheers
                          • caspermccormack
                            • Mar 2012
                            • 112
                            • Ireland
                            #33
                            Hello casper,
                            Still the same as before with the Z board unplugged. I am missing both Va and Vs voltages, all the other voltages are there and all the grounds.
                            • ford2008
                              • Oct 2012
                              • canada
                              #34
                              Can you please indicate how you test/diagnose this bad fet (on/off board?)and which one need to be changed on YSUS # 6871QYH039A, as i changed ipm and it GOT burned again and i suspect of Fet K2673 which got very hot. i want change new IPM202 on Y AND Z SUS need to know if other component such as fets need to be changed. i couldn't find online replacement Fet K2673 on YSUS # 6871QYH039A, is there any advice please.
                              see attached Y SUS include suspected Fet pic
                              • cheebster
                                • May 2008
                                • 373
                                #35
                                Anyone can correct me if im wrong, but this one :
                                http://www.digikey.com/product-searc...9497-5899-5-ND
                                Seems a good replacement. STW9NK70Z is the part number. I've seen those fets shorted on my bad ysus here and you really need to check everything around it since it usually brings a few smd resistors with it, as well as some diodes marked es1g nearby. Multimeter is a must on this one
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • justice171
                                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                  by justice171
                                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                  1. Verified that all critical voltages are present:
                                    • 3.3V and 5V are always present if DC is plugged.
                                    • 1.8V on the BIOS chip is present.
                                  2. Checked the power button functionality:
                                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                    • Confirmed connectivity is intact, ruling out issues
                                  11-26-2024, 12:39 AM
                                • claws77
                                  lenovo flex 5 14itl05 power sequence issue
                                  by claws77
                                  hi guys, my motherboard will not start no matter what
                                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                  but rest nothing happens no sign of life.
                                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                  i have no knowledge of motherboards ....
                                  10-20-2024, 02:48 PM
                                • SuperJames
                                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                  by SuperJames
                                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                  Specs
                                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                  Backstory
                                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                  10-23-2023, 04:09 PM
