Jvc lt-26a61sj
  • Mr_Bodgit
    • 47
    • doncaster
    Jvc lt-26a61sj
    Just got my hands on a jvc TV that was used in a haulage company office 24/7
    they've already sent it for repair inspection and decided the £180 for the power supply repair was too much for its age so they got a new one,
    so thanks to them diagnostics was made a lot easier lol
    I'v not powered it up as don't want to risk anything being damaged
    so i went strait to the psu and what a surprise!
    on the 24vdc side it has 2x capxon 2200uf 35v, and after a coil a 1x 1200uf 35v caps all buldged (no other caps on this supply)
    on the 12vd side it has 1x capxon 470uf 35v that is all so buldged
    (there are three caps that have been replace before on this side, 1x 1000uf 25v and a 470uf 25v, ether side of the bad 470uf 25v) and one 1000uf 25v just before the output power connector
    question is should i just get rid of all capxon capacitors fitted or just try the buldged ones first and go from there?
    heres a pic, the ones marked in red are buldged, ones marked "...linked..." are on same circiut and linked
    Regs
    Rich
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Jvc lt-26a61sj
    on the 24vdc side it has 2x capxon 2200uf 35v, and 1x 1200uf 35v caps all buldged (no other caps on this supply)
    Seeing bulged Capxon is no surprise to anyone who frequents here.
    question is should i just get rid of any capxon capacitors fitted or just try the buldged ones first and go from there?
    The standard recommendation from members here is to replace all the caps, especially Capxon. The biggest one rarely, but not never, fails.
    If you are in the USA, follow PlainBill's instructions on how to order Panasonic FR or FM caps (use FC if the previous are out of stock) at
    https://www.badcaps.net/forum/showpo...33&postcount=2
    --- begin sig file ---
    --- end sig file ---
    • Mr_Bodgit
      • 47
      • doncaster
      Re: Jvc lt-26a61sj
      i'm in the uk but digi-key cover it so no problem there, if not there's RS or Farnell, i'll put a list together n have a look,
      do you think the little blue disk style caps will be ok or shall i look for new ones aswell?
      Regs
      Rich
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Jvc lt-26a61sj
        Those rarely, but not never, fail. You will know it if they fail.
        • Mr_Bodgit
          • 47
          • doncaster
          Re: Jvc lt-26a61sj
          cheers RC
          found all of them so ordering from digi-key, RS and farnell prices are a joke
          all FM series except one (10uf 35v) that's an M.
          posted a pic of my order, do the part numbers look familiar if you'v ever ordered the same at some point?
          Regs
          Rich
          • retiredcaps
            • Apr 2010
            • 9271
            Re: Jvc lt-26a61sj
            As long as you verified all the uF, voltage, diameter, and height (important due to heatsink clearance), the order looks fine.
            You may want to consider ordering a spare cap or two or some other items given the high cost of shipping?
            • retiredcaps
              • Apr 2010
              • 9271
              Re: Jvc lt-26a61sj
              I forgot to mention the "M" series.
              If it fits, digikey has the Panasonic FC cap in 10uF 50V. Check the dimensions to see if you have enough height clearance and diameter width.
              The FC is better suited that the "M" series.
              • Mr_Bodgit
                • 47
                • doncaster
                Re: Jvc lt-26a61sj
                will do.
                Rich
                  KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                  by momaka
                  For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                  http://www.rmac.kingwin.com/products.../abt_650MM.asp
                  I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                  What mostly drew me into buying it is its 2x PCI-E power connectors...
                  03-29-2022, 11:34 PM
                • flibidy
                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                  by flibidy
                  I have here a Magnum IA.100 which belongs to my parents.
                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                  What Ive done........
                  01-01-2025, 01:26 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • bouny56
                  Lenovo E15 Nm-c421 usb-c work only in one side
                  by bouny56
                  ​Hello
                  Laptop E15 I5 10gen
                  Mb nm-c421
                  I have a problem with the usb-c power dc.
                  The motherboard start only in one side of the usb-c
                  Replace the usb-c port 2 times same problem
                  With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
                  Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
                  Can the pd controler be the fault ? Or something else maybe ?
                  Thx
                  02-11-2025, 03:15 AM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
