hi! i have just removed a high esr, smd electrolytic capacitor from a lcd tv mainboard with the following numbers on it..14109/10/50f can anyone tell me the value of this,have searched the web for hours,still no joy,thanks guy's
smd capacitor id needed..
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by cloudff7there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
by GentianI have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
by veedoHello
I've got an Asus laptop which received with no power, so I found that one capacitor been damaged. I don't have schematics for that board which is DANJMMB11A0 REV:A
Without that caps laptop is turning on fine so problem more likely is sorted but I would like to put back the correct one as it should be.
If any way could help with sorting out specification somehow, I just know that my meter shows 11,2uF but is it 50V or 10V ?? or any others.
See attached photo off the capacitor, maybe someone have same motherboard and can check it for me please.
by AleXis6Guys. could you help me please to decode some codes of main capacitor's producers.
I would like to know the manufacturing date.
Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
If I understood correctly:
1. Nichicons marks date of production as (see the attached pictures) H2116
I don't understand the meaning of first letter - may be it is code of factory.
21 -year
16 week
I bought this capacitor recently.
another one-
2....-
- Loading...
