Westinghouse SK-19h210s
  • rlee
    • Aug 2009
    • 6
    I aquired a non working Westinghouse SK-19h210s. When I plugged it in there was no power, no blue light. I have inspected the power supply board (DAC-19M015) and i found the smd fuse near C103 is broken. All caps are looking good.
    I repalce the fuse with a smd resitor (0 ohm).
    When I powered on, the blue light come out, after couple seconds, Q1 on the analog board (A190A5-A05) burned out.
    I am thinking of replacing the transistor Q1, however, I don't know the part number.
    I wonder if anyone has similar issue.
    Thanks in advance.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Westinghouse SK-19h210s
    Thanks in advance.
    Yes, many foolish people have shorted across a blown fuse and damaged another part.
    PlainBill
    • ifly
      • Jan 2011
      • 10
      Thanks in advance.
      Q1 is 7KWWH. I hope you can help me I need to know what Q21 is on that same board. It's not to far from Q1, it's by the display connector.
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
      • jesterace
        Samsung UE46ES8000 Blown fuse but no other signs of short
        by jesterace
        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
        09-11-2024, 03:14 PM
      • jshhh
        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
        by jshhh
        Hi guys,
        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
        Anybody know how to remove this type of fuse?
        (The fuse is toward the bottom of the image labeled F2)...
        06-17-2025, 01:35 AM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
