RCA VKP-900, VKP-900T schematic?
  • smartjohn
    • Feb 2013
    • 116
    I really need help finding a schematic for the model in the subject!!
    I recently acquired this old (1980's pre-camcorder) portable VCR and camera combo unit. The portable VCR docks into a tabletop tuner unit to make it part of the whole TV system.
    The status of the system is: I hit power, and the VCR unit flaSHES ON for one second and then drops back to off. I found one youtube video for disassembly with good detail on how all the interconnections for the boards work. I also downloaded the sam's VCR-208 book that covers this model, but NO SCHEMATICS were in the booklet!! Only a parts GRID locator, alignment instructions, and parts lists. I checked all the typical online schematic download sites but nothing is popping up!!
    Any suggestions would be appreciated!!!
  • zen
    PS48 Bose sub & head unit schematic / advice please.
    by zen
    PS48 is model for sub & where i suspect issue lies .
    CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
    Can't seem to measure any voltages at secondary side of PSU within SUB unit ....
    07-08-2022, 07:53 AM
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • atunguyd
    Acer x163w Monitor PSU schematic
    by atunguyd
    Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
    The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
    03-05-2025, 02:08 PM
  • Mark R
    The Overseas Only Kenwood Model KR 790
    by Mark R
    I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
    The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
    09-23-2025, 08:27 PM
  • ngml
    Repair of an LG split AC system indoor unit PCB
    by ngml
    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
    This indicates an error in the communication between the outdoor and the indoor unit.
    The outdoor unit is fine, so the problem is the indoor PCB.
    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
    Does anybody have the schematics of this board,...
    02-01-2025, 12:55 PM
