LG 47" 47LV4400 Shutting Off LV Series
  • Acesales
    • Jun 2017
    • 58
    Hello again, my year 2011 47" LG 47LV4400-UA is now shutting off after a few minutes. Turns on and works fine then loses backlight, sound, and picture. Power light does not change, stays blue. I don't see a BGA processor to reflow like other LV series. Do the edge type processors also have cold solder joint problems or is this a different issue? Thanks
    • 12192
    • U.S.
    Re: LG 47" 47LV4400 Shutting Off LV Series
    Try this, for those few minutes it's on, go into picture menu-picture mode-backlights, turn them way down, then try the tv and see if it stays on longer.
    • Acesales
      • Jun 2017
      • 58
      Ok, I was able to go in and turn brightness and backlight all the way to zero. It still shut off right away, seems like it's getting worse.
        • 12192
        • U.S.
        Try heating the electrolytic capacitors with a hairdryer for a few minutes, then try it while it's still hot, if no difference, check the bottom of board for anything obvious, check those solder joints, can search images of bad solder joints, sometimes the bad ones can be tricky to see but I guess mostly they will be cracked looking.
        • Acesales
          • Jun 2017
          • 58
          Do you mean electrolytics on the main board or the power supply board? Thanks
            • 12192
            • U.S.
            Try powerboard first, no joy, try mainboard, it's just a little test that will bring the esr of a bad cap down just enough to let tv work for a bit if the cap isn't too far gone. Need to try it while it's still hot.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4326
              • Italy - Milan
              Examine with microscope or power magnifier the solderings of main processor
              • Acesales
                • Jun 2017
                • 58
                I heated the electrolytics on the power board and it came back to life! It ran for five minutes then the wife said we have to leave so I turned it off. I tried heating them again and it won't stay working this time. Was heating them to lower the ESR a one time only test or was it all coincidence?
                  • 12192
                  • U.S.
                  It's kind of hard to tell, I think I would switch out those electrolytics, they've been working hard for 12 years, even if it don't fix it, it will eliminate them from being the culprit.
                    • 12192
                    • U.S.
                    If you don't want to change them all, maybe start with those 5 by the connectors.
                    • EazyBone
                      • Jun 2023
                      • 1328
                      • United states
                      I've seen you suggest the heating many times and first post I've seen work so far. Pretty cool. Curious to see results here. Post if you fix
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4326
                        • Italy - Milan
                        I suggest to not replace any cap cause Delta brand uses best brands caps, here probably Nichicon, the test of haidryer has no evidence here, you probably are a newbie and end to replace with s**t caps, you can try to heat the cpu but an hairdyer is not enough for me , you need an air soldering station or heat gun
                          • 12192
                          • U.S.
                          Some know it alls don't know shit, EVEN the best caps wear out and die.
                            • 12192
                            • U.S.
                            You haven't been here long, that's an old test that's been working for a very long time.
                              • 12192
                              • U.S.
                              I didn't say take the caps out and throw them away, you don't have a cap tester, so I suggested replacing those 5 and see if it works, you can always put the other caps back in but why would you if you replaced them with quality 105 low esr caps. You would have to ask the "expert" that said don't replace them, lol.
                              • Acesales
                                • Jun 2017
                                • 58
                                I reflowed most all of the through hole components on the power supply board. TV worked for about 25 minutes and shut off again. I'll look at replacing the electrolytics now.
                                  ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                                  This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-12-2024, 03:28 PM
                                  ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                                  This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                                  This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                                  This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                                  This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
