Samsung SyncMaster T24B350
  • lotas
    • Jan 2016
    • 4841
    • Russia
    Re: Samsung SyncMaster T24B350
    Yes, in this video he replaced the LDO with 3.3v (sot-23) on a board with a regulator.
    • lotas
      • Jan 2016
      • 4841
      • Russia
      Originally posted by jason123
      Thanks.. I can't understand Hindi, but I think my board checks out except for the Memory Chips VCC.
      I found this video of a board with very similar problem to mine. But I'm not sure how he fixed it.
      https://www.youtube.com/watch?v=iJQIbeiXhsg
      My transistor (NPN I believe is getting 0.39 V on top pin, then 0.823 V (same as VCC on memory) on bottom right, and about 0 V on bottom left. I don't know why it's not getting 5 V on top pin??
      This is not a transistor, it's an LDO at 3.3v.
      • jason123
        • Oct 2015
        • 1136
        Ok.. Quick Update. All videos, though not in english, implied the little transistor gets +5.2 V from the board and generates the Mem_VCC. However, upon running continuity check the MEM_VCC comes from Standby Voltage from the PS board!!!! I was not providing that, I was simply providing +5V, +11.9V, and GND.
        Now with +5, STB(+5) and 11.9V with GND, the little transistor is getting 5V, but still the bottom right (Mem_VCC) is only coming to +.9 V. I don't know how that 3.3 is supposed to be generated. Looks like one trace goes to CPU, and others go to resistors (voltage dividers? - 22k and 10k = ~3.4 V Checks out)
        • lotas
          • Jan 2016
          • 4841
          • Russia
          It's something like this (with a fixed output voltage of 3.3v).
          • jason123
            • Oct 2015
            • 1136
            Thanks I searched for that marking and came up with NPN.
            Any idea what part number that is? it does seem that the regulator is bad, correct?
            • lotas
              • Jan 2016
              • 4841
              • Russia
              #26
              You can use:
              S-1206B33-MT1G,
              TS9011SCX,
              MCP1700T3302E...
              Yes, and you can solder some kind of 1117 33 to check on short wires.
              • jason123
                • Oct 2015
                • 1136
                Thank you.. On order
                • jason123
                  • Oct 2015
                  • 1136
                  You can use:
                  S-1206B33-MT1G,
                  TS9011SCX,
                  MCP1700T3302E...
                  Sorry, I didn't understand: Yes, and you can solder some kind of 1117 33 to check on short wires.
                  Do you mean I use high output current device to test and see how much the 3.3 V node is drawing??
                  • lotas
                    • Jan 2016
                    • 4841
                    • Russia
                    #29
                    I meant to find the most popular regulator (1117 33), it also has a fixed voltage of 3.3v, solder three wires to the legs and solder the other ends to the board, instead of the original one.
                    • jason123
                      • Oct 2015
                      • 1136
                      Prepping the board - removed the regulator, and it looks like the 3.3 pin was barely hanging in there. But I measured the impedance between GND and 3.3 V node, and it's only ~30 Ohm.. is that right? I guess 3.3/30 is about 110 mA, but it seems very low.
                      • lotas
                        • Jan 2016
                        • 4841
                        • Russia
                        #31
                        Usually, like in such Samsung boards, because of this capacitor that you changed in the power supply, the motherboard also suffers, namely this regulator for 3.3v and micom Weltrend wt61p805, but I don’t see it on your board, maybe it’s located on another sides.
                        I just found a photo of your board, there’s nothing on the back side, you need to supply somewhere 2v from the laboratory power supply to this 3.3v point and observe what can heat up by increasing the current on the power supply and find the culprit who drains this power, this can maybe a ceramic capacitor, spi flash, eeprom,...
                        • jason123
                          • Oct 2015
                          • 1136
                          I did comnect the on-board 3.3v to this node while regulator still on. No damage or overheating
                          • lotas
                            • Jan 2016
                            • 4841
                            • Russia
                            #33
                            But 30 Ohm is a low resistance for such a regulator, which drains the power supply.
                            • jason123
                              • Oct 2015
                              • 1136
                              Not sure if we can assume with power (3.3 V present) that 30 Ohm will result in 110 mA usage and that's 0.363 W for standby usage? (in addition to PS standby current?)
                              Anyway, LDOs are on order. and I don't know where the leakage is to get the 30 ohm. I see quite few ceramic caps, and one can be semi shorted, but not sure how to detect as ESR doesn't seem to catch them all.
                              • lotas
                                • Jan 2016
                                • 4841
                                • Russia
                                #35
                                But only when applying an external power supply and increasing the current, try to carefully lift the legs of the spi flash (1,2) and eeprom (8) to eliminate them.
                                • jason123
                                  • Oct 2015
                                  • 1136
                                  Final Update: Ok, got the regulator, put it onboard, and voila, 3.3 is present. However, board still not turning on, and SOT23 is warmer than I'd like to see. Lifted the pins as in #35, no luck, still 31.5 Ohm across 3.3 and GND. Removed all caps on the line that I could see. Still 31.5 Ohm. Removed both memory chips on board - still no change.. at this point, board is throw away, so I removed the Big BGA / Processor and there it is. Must have had shorted pins or internal chip issue ... impedance now is 684 kOhm across the LDO (3.3 and GND) and the board is a designated as donor board
                                  That's a wrap up.. thanks for the help.
                                  • PNI E.
                                    Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                    by PNI E.
                                    Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                    03-17-2025, 04:23 AM
                                    09-07-2024, 05:50 AM
                                  • JSin21
                                    Compatibility of main boards between different variations of samsung MU6100
                                    by JSin21
                                    Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                    I have Samsung Smart TV UA65MU6100WXXY version DA01
                                    Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                    11-27-2023, 04:54 AM
                                  • mrautom8
                                    Samsung TV UN75H6350AFXZC main board schematics?
                                    by mrautom8
                                    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                    While relay is on, all voltage rails are present and steady (scoped) on main board.
                                    I love a good logic puzzle but getting lost without any schematics.
                                    No shorts on ANY capacitor main board.
                                    Thermal camera shows 3.3V inductor getting warm instantly but...
                                    10-19-2025, 06:32 PM
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
