Viewsonic N2635W freezing
  • rlee
    • Aug 2009
    • 6
    I acquired a Viewsonic LCD TV model N2635W.
    The unit works fine for a several minutes and it freezes.
    And later on it restarts but without the sound.
    after turning of the unit for a 5 to 10 minutes , the unit powers on and after freezes again.
    any body has similar issue?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Viewsonic N2635W freezing
    Sounds like its overheating. Point a big old box fan or something at it and see if it stays on longer?
    • rlee
      • Aug 2009
      • 6
      Thanks for the suggestion. I put a fan on the back of the LCD.. and the TV has been running for 5 hours now without single freezing. .
      The fan seems cooling the LCD and preventing the overheating.
      Is there any faulty component inside that causes overheating..
      I am thinking of installing a small fan inside the TV.
      thanks again
      • PlainBill
        • Feb 2009
        • 7034
        thanks again
        Try checking (carefully) inside for the thermally sensitive component. A small cooling fan, a heat sink might do the job, or it is even possible a thermal transfer pad may have been omitted.
        PlainBill
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I dont suggest messing around/feeling aroun for hot components. You kight get shocked or the tv could get damaged. Just add a small fan somewhere inside...
          Ps: lol i was right! Not bad for my first time answered a tv questiom
          • mbates14
            • May 2005
            • 169
            usually the solder balls break on the CPU BGA and causes just this. you can heatsink the main CPU and put a fan on it, or reflow the BGA with a heatgun controllably.
            • ngml
              Repair of an LG split AC system indoor unit PCB
              by ngml
              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
              This indicates an error in the communication between the outdoor and the indoor unit.
              The outdoor unit is fine, so the problem is the indoor PCB.
              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
              Does anybody have the schematics of this board,...
              02-01-2025, 12:55 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • DrDos
              Unit runs but no speaker output kenwood KR-6030
              by DrDos
              I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
              09-14-2025, 09:57 PM
            • FShahid
              Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
              by FShahid
              Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
              This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
              Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
              The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
              Since...
              04-26-2022, 04:41 PM
            • grosseader
              MSI B450 Gaming Plus Max - freezes randomly
              by grosseader
              Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
              What is the issue:
              PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
              Hardware:
              MSI B450 Gaming Plus Max , MSI A320m A-pro
              BIOS : 7B86vHG - latest
              CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
              GPU: Vega 7 in 3200g and MSI 1060 6GB
              RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
              01-30-2023, 03:24 PM
