samsung ue325000akw it doesnt turn on
  • Wolf1977
    • Jul 2023
    • 59
    • Greece
    hi
    i have the above model and it doesnt light even the standby
    i changed the mosfet 60r580p changed the fuse 3,15 a
    removed the shunt and again the same
    i measured in two big voltages capacitors 310 volt dc but no other voltages
    can you advice me someone ;
    the power supply is bn44 00697a
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Re: samsung ue325000akw it doesnt turn on
    Put pictures. Not sure why you would be changing mosfets and fuse..? Was fuse dead?
    Check voltages leaving the PSU board, put pictures and report voltages here. There isn't enough data
    • Wolf1977
      • Jul 2023
      • 59
      • Greece
      i will do it sir
      thanks for the help
      • Wolf1977
        • Jul 2023
        • 59
        • Greece
        i found a stranger ic 8 pin sem 3330 it was shunt i removed
        i saw there is only in aliexpress it was late come and see if the tv works again
        i saw in an old concersation here someone had the same problem with me changed the above ic and after it happens more damage
        i ask if someone kas find an equivalent with mine ic
        thanks on advance
        • lotas
          • Jan 2016
          • 4842
          • Russia
          S3330 (sem3330) =fan6755w
          • Wolf1977
            • Jul 2023
            • 59
            • Greece
            thanks sir
              09-07-2024, 05:50 AM
            • objecttothis
              EVGA 430W PSU Correct voltages but computer won't turn on
              by objecttothis
              I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
              02-08-2025, 11:19 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
