Samsung Plazma Blues Model PN59D550C1F
  • oneduane
    • Sep 2023
    • 10
    I Am Looking For Some Direction, Or Suggestions On Where I Should Focus My Attention. I Have A 59 Inch Samsung Plazma Tv. The Tv Was Working Decently, Maybe Once In A Blue Moon, I Had To Unplug And Plug It Back In, As The Tv Would Just Shut Down And The Standby LED Light Would Come On And Stay On. If You Tried To Turn The Set Back On, The LED Standby Light Would Blink Rapidly Until You Released The Remote Button. Too Fast For Flash Codes. Once Plugged Back In, The Set Would Work Fine, Sometimes For Months. I Took The Back Off Of It, As The Was Some Distorted Pixels On The Right Side About 1/2 Way Up, Only Visible Under Certain Colors. I Noticed The 13 Pin Harness The Joins The Y-Sustain Board To The X-Sustain Board, On The Y-Board Connection, The Center 4-5 Wire Insulation Was Burned Off. I Replaced The Cable And Both Boards, The Tv Now Works For Maybe An Hour Or 2 And Just Shuts Off. Standby Light Comes On And Will Blink Rapidly If You Touch Any Button On The Remote. Too Fast For Flash Codes. Unplug The Set And Will Turn Back On For A Bit And Repeats. I Removed The Back And Decided To Use My Thermal Imager. The 13 Pin Cable I Replaced, The Same Wires That Burnt Are Averaging 150 Degrees F At The Y Board And Across To The X Board. The Power Board Has Been Changed, The X & Y Boards, Have Been Replaced, Supposedly NOS Boards, As Well As Buffer Boards, On Both Sides. Any Help Would Be Greatly Appreciated.
    Thanks In Advance, Duane.
  • oneduane
    • Sep 2023
    • 10
    Re: Samsung Plazma Blues Model PN59D550C1F
    Sorry I Forgot To Post The Voltages.
    The VS Voltage Is Supposed To Be 217 VDC, Actual Reading Is 208 VDC, The VA Voltage Is Supposed To Be 55 VDC, Actual Is 55 VDC, VE Voltage Is Supposed To Be 95 VDC, Actual Reading Is 108 VDC.
    The 13 Pin Harness Connecting The Y And X Board Are As Follows.
    1) VDD-DET 5 Volts
    2) 15 Volts
    3) Verc 130 Volts
    4) Verc 130 Volts
    5) Gnd
    6) Verc 130 Volts
    7) Verc 130 Volts
    8) Gnd
    9) Verc 130 Volts
    10) Verc 130 Volts
    11) VE 108 Volts
    12) VS 208 Volts
    13) VS 208 Volts
    Pins #5-8 Are Extremely Hot, #5 Glows White Under Thermal Imaging. This Is A Replacement Harness, As The Original One Pins #5-8. The Insulation Was Burned Off About 2 Inches, As Well As The Pin Connector On The Y Board.
    Thanks In Advance.
    • oneduane
      • Sep 2023
      • 10
      Sorry For So Many Posts, I Am New At This.
      Here Are The Part Numbers For The 3 Main Boards.
      The Main Power Board Is A BN44-00445A
      The Y-Main Board Is A LJ41-09453A
      The X Main Board Is A LJ41-09452A
      I Have Some Experience Checking And Replacing Some Components, All The Capacitors Appear To Be In Good Working Condition, Resistors And Diodes On The Main Power Board Check Out Good.
      Last edited by oneduane; 09-12-2023, 10:55 AM. Reason: New At Posting / Asking For Help
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        Why Do You Write Like This?
        No photos...
        Anyway, check the pins on the boards to see if they are clean, the connector has to be properly seated and not bent at an angle, maybe take out individually each wire and tighten down the clamps inside it to increase the contact pressure.
        Why is the tv shutting down, I do not know, but the bliking of the led when the remote is pressed is normal and does not have anything to do with a code.
        • oneduane
          • Sep 2023
          • 10
          sorry about the writing, force of habit. not sure why the tv shuts down, will only turn back on, if you do a hard restart ( unplug for a few minutes and plug it back in ). all the connections are clean and tight. I understand that the LED is supposed to blink when you press the remote, this blinking is extremely rapid not as normal. I have read that the main cause is a bad Y-sus board or main power board. I have replaced the boards and the same thing happens. How do you post pictures. I have clicked on insert image, cannot figure out how to do the address, not computer savvy yet.
          Thanks in advance, Duane.
            • 12200
            • U.S.
            Right below your post, click go advanced and manage attachments.
            • oneduane
              • Sep 2023
              • 10
              ok thank you, will give it a try.
              • oneduane
                • Sep 2023
                • 10
                sorry for the delay, could not figure out how to upload pictures, thank you nomoresonys for the assist.
                here are some pics of the boards, Y-main with and without buffers, main power, X-main with and without buffers.
                Sorry a few are sideways, they orientated correctly when uploaded.
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Start by replacing these 10uf 50v caps. They are on the y-main board.
                  • oneduane
                    • Sep 2023
                    • 10
                    ok thank you. i will give it a try.
                    • oneduane
                      • Sep 2023
                      • 10
                      I replaced the 3 caps, and nothing has changed, the TV works great for a while, then randomly just shuts down suddenly. it will not restart until you unplug the set and plug it back in. It has gone for a week with no issues, to shutting down after a few hours. It is not consistent. I do not know if a short video can be uploaded, I will try to video the TV working and after it shuts down.
                      Duane.
                      • oneduane
                        • Sep 2023
                        • 10
                        Sorry I have not been on lately, wife is having some major health issues, tv has to put on the back burner for now.
                          09-07-2024, 05:50 AM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
                          Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                          This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 06:20 PM
