Samsung UN70KU6300F tv troubleshooting
  • Kel65
    • Sep 2023
    • 13
    Re: Samsung UN70KU6300F tv troubleshooting
    Another there, make sure you remove the screws holding where the power plug goes into the board if there is one, see how he does it there: https://www.youtube.com/watch?v=uOr8rLj_rTk
    Thanks. That's the one. The first video I watched didn't do anything with those screws. Glad I didn't slam it too hard.
    I took the power board out and looked at the back to see if anything looked fried. I didn't realize there was so many components on the back, and small. Couldn't see anything obvious. Tomorrow I will take some measurements.
    Thanks for the help everyone. Maybe by the time I am done I will have spent enough in parts to have just bought a new tv
      • 12330
      • U.S.
      While your back there look the solder joints over closely, reflow any that look suspicious, being careful not to bridge anything, examples of bad joints there: https://www.google.com/search?client...h=599&dpr=1.09
        • 12330
        • U.S.
        Simple test, with tv unplugged check every diode on top of the board, meter in diode mode.
        • Kel65
          • Sep 2023
          • 13
          I think I will just focus on the outputs again to make sure I didn’t measure something incorrectly before. My eyes and soldering skills aren’t good enough to replace components. I just don’t want to foolishly replace a board that doesn’t need to be although I understand in this situation it may happen anyway.
            • 12330
            • U.S.
            Well even if you don't replace on component level, the simple testing is to see if you find a bad component, then you can feel better about which board you need to replace, if it is a bad board.
            • Kel65
              • Sep 2023
              • 13
              Measurements once again for CNM803 show a good ground for pins 10, 11, and 12. Measurements on the other pins fluctuate so fast I can't get an accurate reading. Best I can tell is that the best pins top out at 6.x volts and then drop back down. I tried to see if the fluctuations varied with the backlighting flashing at 1 second intervals but could not definitively say. None of the voltages were really stable enough to be sure what the actual reading is. This is with the output cable from the power supply to the main board disconnected. Using a mounting screw for the ground which seemed to work fine for continuity so I would hope it was sufficient for power.
              Think I'm going to throw the power board at it now since I've had my fun trying to dig in deeper. Figured I would learn more by continuing to troubleshoot but I think the main thing I've learned is I forgot more than I ever knew.
              There's a reason I have stayed away from free tv's. We have just become attached to this thing sitting in the living room so I'll drop a little money on it.
                • 12330
                • U.S.
                #27
                I think the problem is the powerboard too.
                • Kel65
                  • Sep 2023
                  • 13
                  Success! $80 power board. Thanks everyone for the tips
                    • 12330
                    • U.S.
                    #29
                    Glad to hear it, thanks for followup.
                    • ohren
                      by ohren
                      09-08-2023, 05:24 PM
                      09-07-2024, 05:50 AM
                    • Nicktronic
                      Samsung Power Supply Board BN44-00874F
                      by Nicktronic
                      Hey everyone,
                      This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                      Anybody...
                      03-17-2025, 06:20 AM
                    • Per Eriksson
                      Samsung BN44-00808D power supply board troubleshooting
                      by Per Eriksson
                      I was given a samsung 65" lcd tv which is "dead" after a lightning strike.
                      Power supply board is a BN44-00808D , also have the marking L65S6N_FSM
                      Main board is a BN94-10803V
                      I've made some simple test.
                      With main board connected nothing happens when plugged in, no blinking lights or sounds.
                      Also kept it plugged in for a while and checked on the boards with a thermal camera, no hot spots detected.
                      With the main board disconnected the backlights turn on and stay on.
                      Checked the voltages...
                      06-01-2021, 02:51 AM
                    • Asraf Atb
                      by Asraf Atb
                      01-27-2025, 05:02 PM
