Samsung un65mu8000
  • EazyBone
    • Jun 2023
    • 1334
    • United states
    Samsung un65mu8000
    This model is the one with the one connect or whatever.
    Problem. Supposed lightning strike, who knows. Turn on TV, backlight comes on, then goes slightly dim and no picture. No error code, backlight is on. On the very bottom there is a small white line about 3 inches long 1 sm tall, one for each side of screen both evenly. This goes away when disconnecting panel ribbons.
    Power supply. Gives 13v across all pins correctly, gives correct LED voltage to backlight when disconnected from main. PWM 1-13 (or whatever it is) all give 3.3 v all disconnected.
    Plug in 13v to main, all voltages stay same and pwm is 3.3 still.
    Plug in second connector to main, all voltages drop from 3.3 (on PWM) down to like .5, .6, .5, .6 etc. None are 3v. They are steady. The 13v side stays 13 v.
    Similar test with all ribbons to panel disconnected 1 side at a time etc.
    PWM always drops. As a note, backlight stays bright when ribbons connected to main/panel and 13v wire connected to main. They only dim when the PWM ribbon is connected.
    I'm trying to Google what PWM and research what it is. Any advice? Is this a main board issue then? Can we isolate it to this and would it have anything to do with reflowing main chip.
    Thanks ��
  • R_J
    • 9535
    Re: Samsung un65mu8000
    Pulse-width modulation (PWM), in this case it is used to control the intensity of the backlights.
    • EazyBone
      • Jun 2023
      • 1334
      • United states
      Thanks, did some digging and not uncommon for the voltage to drop to I believe.
      Looking like a failed panel can close these here. Tape method showing black
      • Storyteller12
        • Jun 2020
        • 624
        Test the buffer board for shorted caps see if you find any
        • EazyBone
          • Jun 2023
          • 1334
          • United states
          I tested them, found none. Decided base on tape panel method and still got lines it was toast.
          I took all the parts off and found water damage and the chassis rusted, and one of the ribbons to be broken. There she wrote.
            09-07-2024, 05:50 AM
          • stylishconsultant
            un60j620dafxza - Samsung No Display Problem
            by stylishconsultant
            Hi All,
            Need help.
            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
            09-04-2024, 03:26 AM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
          • Yanleb
            Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
            by Yanleb
            Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
            If they are not compatible why did Samsung give them the same part number to begin with?
            08-04-2025, 11:35 PM
          • max789
            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
            by max789
            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
            I made the following tests:
            1. Disconnected the main board from Power Board = backlight works.
            2. Connected the main board and disconnected the T-Con = backlights does not work.
            So I ordered a main board from Ebay also BN41-02156A but from...
            01-18-2024, 06:56 AM
